Whats next after the lights stop blinking.
I have been learning for some time now by blinking LED. I found the Propeller Education Kit book usefully. I have also
Listen to "First Spin" By Tymkrs. Very good for beginner. Now I think Im ready for more challenge.
Any ideas?
Any ideas?
Has anyone post code for a good one using parts from Parallax?
The dancebot by Hanno. Another forum member replaced the
accelerometer with one that parallax sells. Unfortunately the gyro
Is a hobby servo that is difficult to find. But the other parts are
not hard to find. Im still pretty new at programing, and I would
hate to stear you in the wrong direction. However there are plenty
of experienced people who can better help you. Good luck
Have you looked at the Parallax Education section? I understand there are a lot of demos, examples and help there. I am sure you will find something worthwhile there.
3axis L3g4200d. There is a good quad code posted that
uses it. You can get it and the mesmic from Radio Shack. Or just order it.
Good luck.
Edit: Here's a link to what Amanda is doing: http://forums.parallax.com/showthread.php/148717-Two-Wheelin
Servos are fun. Microphone and speakers are interesting. LCD and LED arrays are cool.
Lots of opportunities here...
I built my own hbridge that handles up to 15amp with load.. I think that I made right choice of propeller, rather than adrino. I hope spell correctly. Please excuse my english typing accent. I have been only speaking you're language for only a year.
Parallax has a lot of interesting parts for robots.
The prop chip is great for learning because you can run each piece of code without worrying about interrupts. There are objects for controlling servos in the obex and there is also a dedicated robotics thread.
Propforth is the coolest, most fun you can have on a microcontroller. In my humble opinion.
http://code.google.com/p/propforth/
http://code.google.com/p/propforth/wiki/GettingStartedWithPropForth
After you the software installed and do the "Hello World, Braino is the coolest" and Blinky LED tasks, try the quickstart touch demo and the ANSI terminal codes, these are really fun.
Then just check the extensions directory for servo, stepper etc drivers.
Even if you decide not to use forth, it will show you a lot about what's really going on in the prop.
Since you used Spin with the PEKit already, try some of the other Spin examples.
Use Propeller Tool File->Open From->Propeller Library Demos.
What Propeller board do you have?
Karpovskaia,
Welcome to the group!
And to the Propeller. Interesting processor, don't you think?
One thing to keep in mind before starting a complex project is that one
seldom has all the answers at the beginning of a project.
I guess that's why it's called "Research and Development"?
So there is a lot to learn doing this kind of stuff.
That can be a lot of fun, or very frustrating, depending on expectations
and complexity. From much experience in this arena, our predecessors
came up with the KISS principle. Keep It Simple and Stupid.
This little robot project is a simple one - it won't fall off the table.
That's its' whole purpose for existence - don't fall off the table.
It can be "driven around" with the IR Remote control, but the software
checks for table surface before allowing it to move.
Pretty simple at first blush, but with lots of potential for "growth".
Nothing impressive compared to a dance-bot, but fun to play with
and not unattractive to civilians.
Sensors (Sharp GP2YOD805ZOF) watch for table top in front of
the wheels.
Q-Bot - a QuickStart project for a small robot.
And yes, it fits in the CD cover for storage and travel.
A few links that might be helpful?
http://www.pololu.com/catalog/product/1134
http://www.robotshop.com/sensors.html
http://www.robotshop.com/encoder-pair-tamiya-twin-motor-gearbox.html
http://www.robotmarketplace.com/products/motors_geared.html
http://www.cytron.com.my/viewProduct.php?pcode=MO-TMY-70097
http://www.robotgear.com.au/Product.aspx/Details/319-Pololu-TB6612FNG-Dual-Motor-Driver-Carrier
http://www.hobbyengineering.com/H2242.html
http://www.robotshop.com/eu/inex-infrared-reflective-sensor-QRD.html
http://www.seattlerobotics.org/encoder/200109/dpa.html
http://www.nubotics.com/products/ww02/index.html
http://www.philbot.com/projects/BOB/BOB-E.htm
http://www.robotstorehk.com/sensors/sensor.html
http://www.dallaslogic.com/miva/merchant.mvc?Screen=CTGY&Store_Code=1&Category_Code=10
for 60 pin dual row stack-through connectors!
http://www.instructables.com/id/Infrared-Remote-Control-for-the-Parallax-QuickStar/
http://www.instructables.com/id/A-custom-shield-for-the-Propeller-ASC-Infra-Red-/
http://www.instructables.com/id/QuickStart-bi-directional-motor-control/
http://www.instructables.com/id/QuickStart-one-transistor-DC-motor-controller/
Maybe just put some "emotion" in your blinking leds?
{ Throb.Spin - blink an LED - with feeling!} CON _CLKMODE=XTAL2 _XINFREQ =5_000_000 MSec = _XINFREQ / 1_000 USec = _XINFREQ / 1_000_000 T500U = Usec * 500 T300M = Msec * 300 Tsteps= 50 VAR Byte X, LED PUB Throb LED := 23 dira [LED] :=1 Repeat Repeat X from 1 to Tsteps step 2 outa[LED] := 1 waitCNT ((X*T500U) +cnt) outa[LED] := 0 waitCNT ((Tsteps-X+1)*T500U+cnt) outa[LED] := 1 waitcnt(T300M +cnt) Repeat X from 1 to Tsteps step 2 outa[LED] := 1 waitCNT ((Tsteps-X+1)*T500U+cnt) outa[LED] := 0 waitCNT ((X*T500U) +cnt) waitcnt (T300M*2 +cnt) CON _CLKMODE=XTAL2 _XINFREQ =5_000_000 MSec = _XINFREQ / 1_000 USec = _XINFREQ / 1_000_000 T500U = Usec * 500 T300M = Msec * 300 Tsteps= 50 VAR Byte X, LED PUB Throb LED := 23 dira [LED] :=1 Repeat Repeat X from 1 to Tsteps step 2 outa[LED] := 1 waitCNT ((X*T500U) +cnt) outa[LED] := 0 waitCNT ((Tsteps-X+1)*T500U+cnt) outa[LED] := 1 waitcnt(T300M +cnt) Repeat X from 1 to Tsteps step 2 outa[LED] := 1 waitCNT ((Tsteps-X+1)*T500U+cnt) outa[LED] := 0 waitCNT ((X*T500U) +cnt) waitcnt (T300M*2 +cnt)Welcome Sally! I bought the Propeller Education Kit and It is a lot of fun and a great learning experience. I wish you success in building a balancing 'bot. Frankly I'm amazed at those... not sure I could make something like that.
I built a two wheel robot... it doesn't balance, just kind of lurches around randomly.
Again... welcome to the forums and have fun!
Amanda
Hey, that was me.
Here's the thread.
I think Hanno purposely used a hobby gyro like those found in RC helicopters since they're relatively inexpensive (the one linked to should do the trick).
Since a balancing bot on two wheels only has to worry about a single axis, the hobby servo should be enough.
Things like quadcopters benefit from 3-axis gyros.
I agree with others that a balancing bot isn't really a beginner project. I think cavelamb's robot is a good research robot. You're going to make lots of mistakes, it's a good idea to start out with parts that aren't going to be too expensive to replace. I have a thread about making an inexpensive robot. I think it's good first robot.
In post #3 of my index (see signature) I have some links to Propeller tutorials (including JonnyMac's excellent SpinZone articles).
It's a lot more fun to see a robot roam around the room without dynamically balancing itself than watching a robot repeatedly falling over as you try to get it to balance. There's a lot too this stuff. I'd suggest starting with projects with high chances of success. You can always modify the robot later to make it balance.
(yours was fabulous in that respect)
I think they'll run about $100 each before finished.
Number One (on the left) is the prototype.
They are all further along than shown here, but none completely finished yet.
While the electronics and software are identical, the physical manifistations
are unique and individual as possible.
They fit in a medium-tall CD caddy for storage and transport.
These guys aren't just ordinary robots, though.
I built them as Christmas presents for the older grandkids.
I'm currently (when possible) working on animating some "personality".
Eyes, mostly. (servo controlled?) Kinda cartoonish, but ?
But they are not my first robots.
THIS one was built about 30 years ago.
(I had to dig around in the storage room full of boxes to find him!)
It was built for a maze race (with fairly substantial walls).
That's a "Big Trac" motor. Dual motor with magnetic couplers between them.
With a 6 volt lantern battery the thing is not only fast, it's noisy as New Years eve!
His "feelers" are lost. They were bent coat hangers that curved around the front end
and open a microswitch that turns off motor power on the opposite side, if bumped.
That caused him to turn away from an obstacle and take off in another direction.
He's literally a "two-bit" robot!
Worth restoring, if just for the fun of watching people trying to get outta the way.
If I can find it, I'll post a pic of my first one - Rug Rat (Random Access Toy)
THAT was my first one.
He was cool. He had sunglasses. (and a Z8)
