Boe-Bot beeper volume is pretty low — Parallax Forums
LesLes Posts: 13
edited 2013-08-04 17:13 in Robotics
I hope this is the proper place for this.
How loud is the piezo beeper supplied with the Boe-Bot supposed to be? I admit that I have poor hearing, but I didn't think it was that bad. Hooking it up per the "program start/reset notification" example in the Boe-Bot book, I can only hear it if I put it right up to my ear.
Wife says she can hear it from across the room (show off), but that it is pretty soft.
I have used similar beepers in other projects in the past which seemed pretty loud to me. I just wondered if maybe I got a weak one or maybe it isn't supposed to be very loud in the first place. I realize that this is a plain "element only" piezo unit, not one with the built in driver, so maybe it is inherently soft.
Or maybe my hearing has gotten worse. Last time I had it checked it rolled off at about 8khz, 3khz shouldn't be a problem.
I am using an LED (with appropriate dropping resistor) instead for now.
    edited 2013-08-02 10:09
    How is the piezo wired and what code are you using to control it?
    I know with the Prop, I usually use a transistor to drive the piezo. I'm not sure if a transistor is needed when using the piezo speaker with the Basic Stamp or not.
    edited 2013-08-02 10:57
    IIRC a piezo will be significantly louder at its resonant frequency, pretty high. oMaybe 10khz r 20khz. Try a frequency sweep and see what works best for you.
  • GenetixGenetix Posts: 1,775
    edited 2013-08-02 12:01
    According to the datasheet the resonant frequency is 4000 +/- 500 Hz.
    http://forums.parallax.com/showthread.php/140150-What-are-the-specs-for-the-piezo-speaker-in-Activity-Kit
    edited 2013-08-02 14:51
    IFTRC
    (I failed to recall correctly)
    Thanks for the followup, Genetix! :)
  • LesLes Posts: 13
    edited 2013-08-02 16:05
    Thanks for the replies.
    I tried varying the frequency up and down in 500hz steps with no improvement. No point going past 6khz since my hearing rolls off at about 8khz anyway.
    Per the book, the piezo is connected between P4 and ground, the code is simply:
    FREQOUT 4, 2000, 3000
    I'm sure the BS2 isn't driving the piezo very hard, I was just surprised that it was so quiet, wondering if my hearing had gotten that much worse without me realizing it.
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-08-02 16:35
    Try P4 and P5 with complimented outputs.
    e.g. 10 and then 01 as a AC signal will make a speaker louder.
    edited 2013-08-02 16:38
    Here's a thread about increasing the volume of a piezo speaker.
    I use a different schematic. The one I use has a transistor. I'll try to find the schematic and post it here.
    edited 2013-08-02 16:39
    tonyp12 wrote: »
    Can you do this with a BS2? I thought this was a Propeller only trick.
  • LesLes Posts: 13
    edited 2013-08-02 17:13
    That's ok Duane, I know how to add the transistor. I was just wondering if maybe I got a weak piezo.
    edited 2013-08-02 17:27
    Les wrote: »
    Here's the schematic I have.
                           Vin(+5.0V)
                              │   1KΩ
                              └─┼‣┼─┤Piezo Speaker
       Microcontroller Pin ─────── 2N3904
                                 10KΩ │
                                     Vss
    The piezo speaker is the box under the 1K resistor. (I didn't have a good piezo symbol to use.) The 1K resistor connects connects across the piezo leads.
    I think that's the circuit I use.
    Do you have a different transistor piezo circuit in mind?
    I doubt your piezo is weaker than normal. I've seen several others comment on how soft the sound from the piezo can be.
  • LesLes Posts: 13
    edited 2013-08-02 20:54
    Duane, your schematic is a little unclear, but yes, that's the general idea.
    I'm perfectly happy using the LED instead of the piezo, so I'm good.
    edited 2013-08-02 21:33
    Les wrote: »
    LEDs are great too.
    I did try to clarify the schematic a bit in case anyone else is interested.
    edited 2013-08-02 21:48
    Bit Rot - Time to replace the core memory, Erco :P
    You can also try the circuit Beau Schwabe suggests in Post #4.
    http://forums.parallax.com/showthread.php/62310-Amplifying-piezo-speaker?p=464410&viewfull=1#post464410
    There is also this link where people suggest different fixes.
    http://forums.parallax.com/showthread.php/107689-BS2-amp-Piezo-Speaker
    Here's one using an Op-Amp but you need a dual polarity power supply.
    http://forums.parallax.com/showthread.php/75707-How-to-Amplifying-a-Piezo-Speaker-and-Volume-Control?p=517152#post517152
  • LesLes Posts: 13
    edited 2013-08-03 06:49
    I'll probably add one of the amplifier circuits later when I get the Boe-Bot wondering about the house.
    Thanks for all the input.
    edited 2013-08-03 07:47
    Get a "hamburger speaker" off ebay for $4 and you will hear everything. Self contained amplified speaker, USB rechargeable.
    http://www.ebay.com/sch/i.html?_sop=15&_sacat=0&_from=R40&_nkw=hamburger+speaker&LH_BIN=1
  • WhitWhit Posts: 4,191
    edited 2013-08-03 13:29
    Just to cover all bases - is the cleaning sticker removed?
  • LesLes Posts: 13
    edited 2013-08-03 15:09
    Good point Whit, but yeah, did that first thing.
    I only asked cause I've done it! Doh!
