Re-intro... hello again
I joined the forums a few years ago and got the Boe-Bot and some other BS2 stuff, then life got in the way and the projects got shelved.
Now things are settling down and once more I have a little spare time to pick up where I left off.
The forums have changed quite a bit since I was here last. The history (old posts) doesn't seem to go back very far, I guess all the old stuff disappeared with the forums makeover.
Anyway, I'm glad to be back, just thought I would say "Hi" again.
Welcome back Les!
If you go down to the bottom of each forum, say General in this instance, you will see some drop down boxes. Choose "Show Thread From" and select from the beginning.
You can do that in each forum. You might be able to set that up in your profile, but I would have to check on that.
Jim
On the left side of the page select "General Settings" (under "My Account").
About 2/3 of the way down on the general settings page is the option "Default Thread Age Cut Off" (Under the section "Thread Display Options".
I set this to "Show all threads".
Welcome back.
Thanks for the welcomes too, much appreciated.
