basic stamp 2pe and text to speech (WTS701EF/T) — Parallax Forums
nurulnurul Posts: 2
edited 2013-07-31 07:52 in BASIC Stamp
hi,
i have a text to speech (WTS701EF/T) model and im using a basic stamp 2pe, but i want to listen a word "hello" from the text to speech. can anyone help me on how to start on the code, or give me an example code. thank you.
    edited 2013-07-31 07:16
    The WTS701 uses the SPI protocol with 4 pins as described starting at page 46 of the datasheet. The Stamps, including the BS2pe, use HIGH and LOW to manipulate the SS pin and either SHIFTOUT to send data via the SCLK and MOSI pins or SHIFTIN to receive data via the SCLK and MISO pins. There are plenty of examples of SPI device communications in the Stamp documentation. Look in the Basic Stamp Syntax and Reference Manual and in some of the Nuts and Volts Columns.
