Reasonable expectations for Polar sensor
Hello,
(I usually get started on my homework pretty late....)
What are reasonable expectations of the Polar heart rate sensor setup included with the Inspiration kit? In the only documentation I've found so far, the "Polar Heart Rate Receiver" kickstart, I find this:
Is there a
[/FONT]
[/FONT]
Important! A signal is received only if there is a compatible heart rate sensor transmitter within operating distance (typically four feet or less). The sensor must be worn in accordance with the instructions packaged with it.
[FONT=Verdana, Geneva, Arial, Helvetica, sans-serif]Which leads me to believe a valid 'beat' is available from the Polar xmtr/rcvr. That I'm getting a legitimate or plausible rate count from the demo .spin code. Yet with the transmitter a good fifty feet away from the receiver I'm still getting a large number of 'beats'. With the receiver removed from the circuit I'm not receiving any false 'beats'.Is there a
[/FONT]
- Data sheet available for these parts?
- [FONT=Verdana, Geneva, Arial, Helvetica, sans-serif]More detailed documentation? Perhaps a technical blog post from parallax or Polar?
[/FONT]
[/FONT]
I have a feeling with the beats that you're getting (when the transmitter is 50 feet away), that for some reason it's picking up something else that seems to trigger a default beat pattern. Other electronics?
I built mine off of the Prop BOE and on to a Prop proto board last night. It's better now. Still imperfect.I'll continue to fiddle about...
Bluetooth (XBee form factor), Polar heart rate receiver, Sensirion temperate / humidity sensor.
