another i2c / xmmc question
I need some more help. I am working on a project using xmmc. I have been using the cog_c_toggle demo code as my model. I can open an i2c bus using i2cBootOpen() in the main routine with no problems, however, if I start a cog and try to the do the i2cBootOpen() from there I get an error message.
I can demonstrate my problem using the cog_c_toggle demo code. If I put a i2cBootOpen() in toggle.c it works fine if I put the i2cBootOpen() in toggle_fw.c I get this:
Any help would be greatly appreciated.
bottomshotserver:my_toggle_2 mam1$ make clean rm -f *.o *.elf *.a *.cog *.ecog *.binary bottomshotserver:my_toggle_2 mam1$ make MODEL=xmmc BOARD=c3 propeller-elf-gcc -Os -mxmmc -o toggle.o -c toggle.c propeller-elf-gcc -Os -mcog -r -o toggle_fw.cog toggle_fw.c propeller-elf-objcopy --localize-text --rename-section .text=toggle_fw.cog toggle_fw.cog propeller-elf-gcc -Os -mxmmc -fno-exceptions -fno-rtti -o toggle.elf toggle.o toggle_fw.cog toggle_fw.cog: In function `_main': :(toggle_fw.cog+0x54): relocation truncated to fit: R_PROPELLER_SRC against symbol `_i2cBootOpen' defined in .text section in /opt/parallax/lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/xmmc/libc.a(cogload.o) collect2: ld returned 1 exit status make: *** [toggle.elf] Error 1 bottomshotserver:my_toggle_2 mam1$
Any time you see "relocation truncated to fit" it means your program has grown beyond the limits of the memory model.
If you need i2c access in a COG sized program you have a few choices.
1. Add some code to the COG C file usually via copy paste so you know the stack won't blow up.
2. Use a mailbox handler in a CMM/LMM/XMM* main program that can provide services.
There may be more, but these are obvious to me.
Normally when working with CMM or LMM I see something like
In your case I don't see the amount of overflow bytes.
I used these flags without understanding what they do. Could you point me at any documentation? I clearly need a better understanding of what is happening.
I believe that jazzed is telling me that size of the i2c routines are such that I can not fit them into a cog so the only way to run them is from the main program. Is this correct?
https://code.google.com/p/propgcc/source/browse/lib/include/i2c.h
https://code.google.com/p/propgcc/source/browse/lib/include/i2c_driver.h
