Etching serial numbers on steel
I'm looking for information regarding etching serial numbers on steel, specifically fuel injectors. Volume is low, averaging 15-30 per day. This is relevant, in a bit of a stretch, in that the testing device uses a Prop to accurately generate various width pulses at various periods for various lengths of time. Fuel injectors are cylindrical (10-25mm diameter) so this makes things a little difficult re marking them.
Thanks!
Thanks!
http://www.seton.com/hand-held-engraver-cs60.html?fr=1
Laser engraving is likely what you want.
While one can pick a laser engraver on the surplus market, I would think the cheaper route is to outsource it.
You could simply apply a cost of oil-based paint, and then scratch your number into it by hand or more elegantly by machine. And then brush it with acid to get your etch.
There are a lot of things that are known to resist acid and many are a very thin coat. You can see this with iron-on laser printer ink and markers used to create an acid resist for etching printed circuit boards. So you don't have to be chemist orvuse rocket-science to find some sort of paint that can be applied, let dry, and then removed... all sorts of material will do fine.
You may want to use a shellac. It dries quickly and is removed easily with alcohol. It can be tinted with a color to be more obvious contrast.
Or you can just use bitumen tar dilluted with mineral spirts. It is soft, but it you are working quickly and carefully it will work. Fine artist use this with etching copper plates for printing.
If you are willing accept writing serial numbers by hand, you could also have the craftman that fabricated the piece personally sign his or her initials.
For etching steel. I suppose muratic acid or nitric acid are your choices. Nitric acid cuts fast and deep and takes more effort to control. There are other acids, but they are either more costly or much slower or are very toxic.
but a few specialised ones are).
Having a Trademark followed by the letters TM doesn't require government approval (the 'circle r" represets a Registered Trademark) and can be useful to both identify fakes and to eventually establish a registered trademark. Serial numbers can be faked as well. A personal initial set as proof of origin is a nice touch.
It wouldn't hurt to actually etch a barcode as anyone that desires to fake something will have to sort out what you are doing with the barcode.. it just makes it a bit harder to bother with. Methinks that 4 digits isn't really enough for protection as proof of orign... Code in the Month, the Year, and the Location (maybe a zip code?) and encrypt the obvious info to no longer be an obvious serial number. but provide the obvious serial number to confirm that the encrypted data conforms.
