A Long long time ago, in a galaxy far away: What led you to Parallax?
NWCCTV
So, I was just sitting here browsing through the Forums and got to thinking, it's been almost ten years since I started working with Parallax products and it got me to thinking about what led others to Parallax products. Here's my story: Many years ago, I knew nothing about stepper motors or servo motors. I watched something on the Internet that drew my interest, so I got on the web, found a couple used stepper motors and ordered them. After doing more research, I realized I needed a driver in order to make these motors move. I went to Radio Shack thinking they might have what I need. Boy, was I wrong. However, while browsing around I came across the "What's A Microcontroller" kit. I think it was like $89.99 or something then. I thought, "wow, kind of spendy for a few electronics parts". After reading the back of the manual I thought what the heck, I'll give it a shot. I brought the Serial version home and I was HOOKED!!!! It took me about two days to run through all the projects. After that I found the stepper drivers I needed on line, connected them to my Homework board and I was in heaven. Unfortunately it was not long after that, that life took an unexpected turn and I had to put the hobby away for a few years. Once I picked back up on it I bought my first Boe Bot on EBay and I have been going ever since. I have moved on to the Prop and a "Bigger" Bot is currently being built and I am a happy Parallaxian!
I knew that my signal switcher required some sort of uP or uC to run it and I'd heard about an easy to use uC from an engineer at work. So I poked about the Parallax store, liked what I saw and took the plunge.
One of the better decisions I've made!
With encouragement from Ken Gracey, and my interests as a student, I began putting more stamps together in parallel and this happened. Someone on the Forum continually reminded me I should use the Propeller chip instead of the BASIC Stamp - by the time I built this with 40 props and this with over 100 props, I think he had serious regrets.
I'm always looking for something new, new ways to do things, new techniques and enhancements, new presentations, and Parallax parts are perfect for hobby experimentation, student projects and trying new things.
Parallax is really fantastic because of their innovative parts and processors, well known support and service, the high caliber of the people working there, and the ability to serve the varied interests of so many people across the world all at the same time.
I do remember seeing it in the huge catalog of our local electronics distributor whilst browsing through it looking for micro-controllers.
I do remeber skipping straight passed it very quickly and moving on to the PICs and AVRs etc.
Why did I do that?
1) Eight 32 bits cores is interesting but "obviously" a space of only 512 instructions for "real code" is totally useless.
2) What's this "Spin" thing?.I've already had to learn a dozen languages over the years and really can't stomach YAFL (Work it out:)). Spin is not even any kind of standard or open sourced. Hopeless.
3) There were no dev tools for Linux or Mac. All there was was the Prop Tool which is Windows only. I'd already been bitten by that trap many times and did not want to go there again.
So what happened to pull me in?
Not sure. Was it that pile of dead AVR's on my desk that I could no longer program due to fuse bits getting set? Was it that pile of PICs that just started to Smile me off?
Perhaps.
On the plus side a couple of things turned up. There was a PASM assembler by Cliff Biffle that I could run on Linux. Then HomeSpun, then BST.
At some point I caved in to curiosity and grabbed a DIP Prop from the local ELFA store.
In a moment of clarity (insanity?) I thought there must be an embed solution that we can use - again as the complexity increased the $ went up and the same 'added stuff you wont use' problem occurred . Coupled with interrupts - and interrupts interrupting interrupts....
I encountered Peter Jakacki via a different project through work - he sang the praises of the propeller - So I investigated.
WOW - what a brilliant chip - I was intrigued.
Joined the forums and saw just how helpful the 'forum' people were, the realised that some of those helpful people are ALSO the ones who worked for the company.
Took stock (and was surprised) by how honest and open those people were. A company that actually truly seems to be interested in more than just the $.
I was hooked (and some here are still probably regretting that day
I must ADDITIONALLY say - the reason I stay (other then the brilliant P1 chip) are all the same reasons that got me hooked.
I had been aware of micro-controllers for quite some time, but the reality was that software packages were very expensive. And before the PICs... you had to build boards wtih added RAM and EEprom and even a UART. So there were a lot of burdens to get anything really started.. financial and physical.
Parallax made it easy for everyone to try a micro-controller.
These days, there are a lot of great chips that still don't have the documentaion and the support community to ease the pain. I suppose that is why they don't take the lead that the BS2 once created.
Starting with the Carrier board, I did a couple of truck scale controllers, then designed a general purpose controller board, then a dye injection system and on and on. Since then, there have been probably a 1000 or so Stamp projects (mostly BS2 with the odd BS2sx and px). Everything from a $300,000 tree harvester to a simple ASCII to BCD converter. Even today, the controllers come back for refurb and the Stamp failures have been miniscule.
The Stamps have been used in industrial training programs and loaned to schools and universities. They`ve been interfaced to some real odd-ball equipment and been part of some control systems that nobody else would touch. They have always worked reliably and predictably. Who could ask for more?
Cheers,
Spin is relatively easy to program with and PASM is the same. It is the finer points of the two and the Prop that take time to , pleasingly, learn.
Winning the ELEV-8 name contest enabled me to get a couple of Protoboards (and a few other bits besides). I have Also bought a few of Cluso's 1" x 1" boards .
About 5 years ago, I saw an article somewhere on the Internet about Parallax. I remembered the name from my exposure to the Basic Stamp years before and went to the website. I was amazed at the wealth of products, reasonable prices and the Forums what a gold mine!
I bought a BOE-BOT, put it together and had a lot of fun with it. Then I saw the Stingray, bought one of those. I wanted to graduate to the Propeller. Now Im going to sell my Stingray because I really want a Thumper. I still have my BOE-BOT, but Ive upgraded it to the Propeller. I also have the PPDB and just got my Propeller Activity Board and am eager to start with C on the Prop.
I finally have a practical application. I have a big, old cruiser with twin 4.7L gas engines. I want to build a fuel totalizer system using the Propeller and some form of communication to the bridge for a display of fuel burn, tank quantity, etc. Ive seen a couple of things on the Forum that I might be able to adapt to my needs. Thats my project for next winter.
Somewhere along the line I saw Kens post on the forum for the ELEV-8. I followed the development and got one of the second runs. I went whole-hog and got the Hoverfly Pro and GPS. That hasnt been the greatest experience I still dont have it working properly in spite of sending the Pro back to Hoverfly for adjustment. But Ill get it worked out eventually.
I am so impressed by this company. I have never experienced this level of customer satisfaction as I have from Parallax. Im hooked forever.
I bought my first BS2 back in 1998, but I never really had the time to even get started with it. Fast forward to about 2009. I was looking into creating an automatic coil winder to turn out secondaries for Tesla Coils, so I had been looking at a lot of counter chips. Electronics was in my head. I had also been seeing "What's a Microcontroller" at Radio Shack, and while it interested me, the price, for what I perceived as just an expensive toy for me, made it so I couldn't justify it.
Then one night I had a dream. I was at some sort of tech show, and there was this guy with what looked like a quad-copter. But when I got closer, I saw it had NO rotors. No moving parts at all. Just a bank of thin coils that made it look like some sort of flat flower almost. It silently hovered in space, operated by a remote control. He could make it go up, down... just like a quad-rotor. Not a sound. And in the dream, my focus was drawn right to the center of the board with the coils, and I realized that I recognized the heart of the unit. It was a Basic Stamp. I remember him saying something about it driving the "phase angles" of the coils.
I bought "What's a Microcontroller" the next day.
While I haven't yet revolutionized human travel, the Stamp did launch a new career for me and has been probably the best $89.99 I have ever spent in my life. The return on investment has been staggering! And I've had a LOT of fun.
http://forums.parallax.com/showthread.php/86313-Commodore-64-Emulator
Since Ive been here and met a few BOE Bots Ive decided they shouldnt be abducted and probed. Now I just lay low hoping nobody from Micropopuless finds out I switched sides. Occasionally I transmit fake intel back to confuse them, for instance they think the BS2 has 1000 pins, and AA batteries can put out a megawatt.
I figured the BOEBot must be the one to beat - so I came to Parallax. I loved the Forums and soon found that Mike Green, Phil Pilgrim and many of you knew what I wanted to know.
I was broke at the time and built some small projects from salvaged parts ala Solarbotics and BEAM - but saved my money and got a BOEBot - I've been a Parallax guy ever since - I am also a big Scribbler/S2 believer and love the Prop - I am excited about the new LEARN C stuff too!
Parallax has gotten me more into electronics in general too! But Robotics is main interest.
I was greatly impressed with the documentation.
I've been using Parallax products ever since.
Bean
As an act of mercy, the Tralfamadorians finally released me from prison.
That year, as a consolation prize, the Nobel Committee sent me a strange box that asked me "What's a Microcontroller?"
Answering that question resulted in a religious experience.
The Time Capsule had been opened and I was set free.
The stone rolled away.
I was struck by lightning.
The cows came home.
I began walking on water.
After doing a string of TV commercials for Dos Equis, I had enough money to demonstrate that my one-man suborbital surfboard could make auroral skywriting an Olympic sport.
I then won 41 gold medals by doing just that. (Stick that in your pipe, Michael Phelps, and smoke it.)
Nowadays I work on the next Coolest Thing in All of Human History and plant BitCoins at the beach for old hippies to trip on.
My Arduino-controlled divining rod.
(Just trying to keep up with ElectricAye, who has a snappy answer for everything!)
Is that what you call that little thing?
Moderators are standing by...
And, that in a nutshell, is how my desk has become cluttered with all manner of electrical/electronic stuff! All dedicated to my goal of, as stated in my signature... Aimless Tinkering! Only kind of kidding about the "World Conquest" part. Anyone who wants to rule the =whole world=, clearly has serious issues! ;-)
Amanda
Computers!
My first computer was an Altair 8800A... yeah with all the toggle switches, which I foolishly sold.
Next was a Cosmac ELF kit which was a lot of fun to build.
Following that was a Radio Shack TRS-80 Model I with 16K and level 2 basic. After tiring of all the Basic example programs, I disassembled the ROM by hand so I could write the same boring Basic programs in assembly!
Next was a TRS-80 Model 4... with floppy drives... WOW!!!!
The PC phase, which lasted for years, began with a 10MHz peecee XT that was H**Y C**P fast! I got a deal on a Shugart 5MB hard drive for $179. I mean FIVE MEGABYTES!!! How could I ever use =all= that storage space? ;-)
