Keurig Auto Fill with BS1 and Milone eTape
Here is how I automated refilling my Keurig coffee pot with a BS1 and a 8" Milone eTape.
[video=youtube_share;f-w_Y_e3z-Y]
The BS1 polls the eTape using the "POT" command and opens a 12vDC solenoid through a PN2222 transistor if it is low. It also flashes the LED quickly while filling. To try and prevent an over fill and making a mess while it is filling the BS1 keeps count through the fill loop. If the count limit is reached it will close the solenoid and no longer automatically fill the reservoir untill the power is toggled, the LED is also toggled slowly. If you want to fill the reservoir before it is low you can just press the fill button and it will top off the tank. To get the water to the Keurig I tapped into my refrigerator water supply. I used all 1/4" push to connect fittings and a shut off valve at the T connection.
' {$STAMP BS1}
' {$PBASIC 1.0}
' -----[ I/O Definitions ]-------------------------------------------------
SYMBOL Pbtn = PIN0
SYMBOL Led = 1
SYMBOL Sensor = 2
SYMBOL Valve = 3
SYMBOL scale = 100
'-----[Variables]---------------------------------------------------------
SYMBOL level = B0
SYMBOL count = W1 '0 to 65535
SYMBOL CountLimit = W2
CountLimit=200 '0 to 65535
'-----[ Initialization ]-----------------------------------------------------
'DEBUG CLS 'Debug info for checking fill level.
'GOSUB Var_Data
GOSUB Get_Level
'GOSUB Var_Data
HIGH Led 'Turn the LED on to inidacte power is on.
'-----[Main Code]---------------------------------------------------------
Main_Loop:
GOSUB Get_Level
'GOSUB Var_Data
IF Pbtn=1 AND level>19 THEN Fill
IF level>=38 THEN Fill
PAUSE 100
GOTO Main_Loop
' -----[ Subroutines ]-----------------------------------------------------
Get_Level:
POT Sensor,scale,level 'Check Fluid level
RETURN
Fill:
HIGH Valve 'Open solenoid valve to start filling.
FOR count = 1 TO CountLimit 'If count limit is reached the tank maybe over filling.
GOSUB Get_Level 'Check fill level
'GOSUB Var_Data 'Debug values if needed.
IF Level<=19 THEN close 'If full goes to the Close solenoid routine.
GOSUB Flash 'Goes to the LED flashing routine.
NEXT 'Loop and add one to the counter.
GOTO Alarm 'Goes into error to prevent over filling the tank.
Close:
LOW Valve 'Close solenoid valve.
GOTO Main_Loop
Flash: 'This will flash the LED to indicate the solenoid is open.
HIGH Led
PAUSE 100
LOW Led
PAUSE 100
RETURN
Alarm: 'This will stop and flash a warning light in case of error.
LOW Valve
LOW Led
PAUSE 1000
HIGH Led
PAUSE 1000
GOTO Alarm 'If error occures the power to the Basic Stamp must be reset or powered off before it will work again.
Var_Data: 'For Debuging Purposes.
'DEBUG "level = ", #level
'DEBUG " Count = ", #Count, CR
RETURN
Keurig Auto-Fill.bs1 Keurig Button-Fill.bs1
I am pleased to see another BS1 project! Seems to be fewer and fewer these days.
Doc
http://goo.gl/KX1Mq (Link to Grainger) I’m powering it with 12v with a pn2222a transistor.
Great project - my Dad is hooked on his Keurig and we are always refilling it!
Thanks also for the link to the EOD Memorial - learned something new...
I fought hard against getting one of these coffee makers, I thought it was a gimmick first time I saw one in the store,
We got had to use one for a weekend, Now I don't want to be without my Keurig.
Thanks for sharing, and congrats on making 'project of the week'.
-Tommy
