Fried Demo Board!
After connecting +9 V to pin 7 of the prop chip on my demo board, I get that infamous "no propellers found" message from the spin tool. I really like the board for quick testing of projects. Is there anyone around that could jack up the old chip and drive an new one on the board? I unfortunaely have developed an age related tremor that makes smd work impossible.
Jim
Jim
I have had tremors for quite a few years. If you can remove the chip cleanly, try tacking down diagonally opposite corners first to get the position exactly right. Then the tremors won't matter all it. The rest is just a quick bit of soldering.
Send the board to me. I'll try to fix it.
I'll PM you my address.
I PM'd him and hour ago. We will see what he gets first.
Being in Taiwan and not having any surface mount Propellers on hand ... seemed wisest to let someone else offer.
But you really can solder well with tremors if you take this approach. I did a Schmartt board with a GA144 that is much harder than a Propeller.. finer pitch and more pins. And I have done other stuff as well.
Jim
A bench lens, with light, is the thing that I find most useful on sticking the new one back down. Clean off the old solde wit some wick and then apply a layer of flux to all of the pads (I use a felt tip pen sort) and then with a merest hint of fresh solder do the diagonals. then put some more flux on top of the chip pins and get bold with a larger tip that has nicely rounded edges and just wipe the solder (0.5mm) along the rows. Any excess or bridges can be cleaned up with more flux and gravity or wick.
To remove a bad chip, I've been told to cut the leads with a sharp knife and then remove the leads with a soldering iron. I think this method could work well with a bit more practice on my part but I've still managed to damage a PCB with this technique.
I'm pretty sure all the chips I've removed with Chipquik have caused any damage to the PCB. I'm not really worried about soldering on a new chip. I've done that many many times. The first lead is alway the trickiest though.
Cluso99 gave some smt soldering advice in Jazzed Tetra Prop thread (ignore my babblings). Once I followed his advice rather than trying to do it my way, I've been much more successful with soldering surface mount parts.
Cutting the individual leads is a way, by you have to be so careful that as soon as the lead is diconnected from the IC that it doesn't become an instant lever to stress the PCB.
Blessed were the days when there were sockets, and the pins were a visible distance from each other.
SparkFun sells 2.5 ft of it in their kit.
For pcb layouts, just ensure you extend the pcb pads out at least 0.5mm more than recommended and you will be fine.
And Duane, if you are missing SMT parts to repair this board please contact me and I'll send whatever you need.
http://forums.parallax.com/showthread.php/143015-Improvement-to-the-Propeller-BOE-Lifetime-Warranty
If it's the Prop that's bad, I should be all set. I have lots of QFP Props.
Thanks for the offer. Hopefully Jim won't need to take you up on a replacement board.
Jim
Good on you Duane!
Hey, I offered too.
Duane, just watch that resistor by the microphone.
Jim
Good deal Jim!
Duane, you rule!
With the help of ChipQuik I was able to get the old Prop off without damaging any traces.
The Demo Board is a little harder to work on than some of the other other Propeller boards because of the mic and other components in the area of the Propeller chip. I ended up resorting to my earlier smt soldering technique of using too much solder and the clean it up with solder wick. As you can see below, you don't have to be very precise when applying the solder.
I would have sworn the chip was straight when I soldered the first two leads but as you can see below it's a little crooked.
I didn't want to risk damaging the traces by attempting another chip removal so I left it a bit less than ideal. I'm pretty sure the only down side to the crooked chip is cosmetic. No one tell Jim; maybe he won't notice?
I found demos to test each of the Propeller's I/O pins. I used LEDs to check P0-P7. It all seemed to work okay so hopefully Jim will be good to go.
Duane,
I have also had the same scenario repairing Proto Boards and Propeller Project boards. They look perfect when you solder the corners, but they look skewed afterwards.
But they work!. That's all that matters.
Good job Duane!
