Little Wrenchy — Parallax Forums
Little Wrenchy
Matt GillilandMatt Gilliland Posts: 1,406
edited 2013-07-13 14:40 in General Discussion
So some of you may think we take things to an extreme sometimes... I think that myself.
There's a rumor about some new robot platform or something coming out soon (they don't tell me anything - I'm as much in the dark as you are ;-)
Anyway, I get this secret memo slid under my door a while back asking for a new "wrench" to be included with "the project".
It's a combination wrench made of 1/8" thick delrin and has some pretty cool properties:
a) It's made of delrin, so it's just about indestructible (within reason)
b) The closed end friction fits a 4-40 nylok nut - which means you can pre-load the nut and use the wrench like a dipstick and lower it into tight places- like around high-speed servos, (did I just say that out loud?).
c) The open end works well to a point and then the jaw opens up as you continue to crank on it - then it "slips off" the nut because the nut is tighter to the bolt than the delrin wrench open end - it "opens up". This, at first glance, seemed to be a design.material flaw - but then after further soul-searching - and righteous justification - we realized it operates like a little tiny, preset torque wrench - how cool is that?
d) The niftiest property of all, is that (along with many of our products) it's MADE IN THE USA :-) Surely something this small and insignificant could be made cheaper overseas - but for now - This lowly wrench proudly wears the USA moniker.
-MattG
  • WhitWhit Posts: 4,191
    edited 2013-07-11 15:21
    Keep taking things to the extreme! I want one!
    Why would anyone have a hobby if you couldn't get carried away with it?
    By the way - I think thst part of assemly on a BoeBot is most trying for young users...
  • JonnyMacJonnyMac Posts: 9,434
    edited 2013-07-11 15:24
    I could have used one of those this morning. Rick Galinson called and asked if I wanted to take a break so we could fly our ELEV-8s. "Yes" is generally the answer to that question. I have started a pre-flight check routine of ensure all screws are tight; luckily I had pliers with me to hold onto the locknuts.
    edited 2013-07-11 15:37
    'Looks good, Matt! It can be a real pain to attach those [redacted] to a [redacted], especially when there's also a [redacted] involved. And the nut always seems to tilt away from the screw or escape when held with needlenose pliers. Wrenchy should be a big help -- especially with Nylok nuts!
  • W9GFOW9GFO Posts: 4,010
    edited 2013-07-11 15:55
    You should put it up on Thingiverse when [redacted] is released for some extra free advertising.
    edited 2013-07-11 16:52
    Hey, it's just what I need to tighten my bolts during morning faculty meetings.
    Any chance it will fit on a nose ring?
    edited 2013-07-11 18:49
    Second this notion...
    W9GFO wrote: »
    edited 2013-07-11 19:14
    Personally, I think the [redacted] is probably one of the best [redacted] I have seen in the whole [redacted]. Literally, the [redacted] runs [redacted] around [redacted]'s [redacted]. No [redacted], Sherlock!
  • rjo__rjo__ Posts: 2,114
    edited 2013-07-11 22:19
    Matt,
    You can't fool me.
    It is all an optical illusion. Look carefully... it is the same little wrenchy photographed from two angles and then photoshopped together.
    And it isn't delrin... it is machinable wax. Can't fool me! IF IT IS DELRIN... where is the LED?
    The [redacted]rate is way to [redacted]. It is [redacted]ing the [redacted] plastic.
    But I like it:)
    Make mine out of gold.
    (And put a hole in it to hang my keys from... and an LED so I can see my keyhole... and a GPS so I don't lose my keys.)
    edited 2013-07-11 22:35
    Are you going to offer left handed versions also? :lol:
  • DaveJensonDaveJenson Posts: 385
    edited 2013-07-12 07:22
    I want one (or two)! (Right or left handed....)
    edited 2013-07-12 10:09
    I'd like one left handed and one right handed so I can get twice as much done in a day.
  • Desy2820Desy2820 Posts: 138
    edited 2013-07-13 11:27
    Hmmm. I'd like a pair of these, with an inventor's wand, please. I'd also like to pre-order a [redacted].
    Thanks!
    edited 2013-07-13 12:46
    Wasn't "Little Wrenchy" the name of Vinnie the Blade's bagman in Manhattan Misfits? IIRC he was played by Joe Pesci.
    @Phil - No, Little Wrenchy was Lucy and Desi's son.
    Remember when he learned to play the drums?
    150 x 200 - 22K
