Help! My new Makerbot Replicator 2 is not working!
Hi,
Anybody has experience with Makerbot Replicator 2?
After going though the calibration steps, the LCD display just went blank. Pressing the buttons produced no sound.
I opened the bottom cover and found that the fuse is intact and the power adapter is still supplying 24v to the ATMega1280 board. Some leds on the board is still lit.
I found that the ATMega1280 chip is too hot to touch after switching on for a few seconds. Is this normal?
I also found that the ATMega board supplies almost 9v to the stepper motor controllers even though the stepper module silkscreen indicates 5v only. Is this expected?
Anybody has a Propeller board I can replace the ATMega1280 board with?
Thanks in advance.
Thanks in advance.
I did start a Makerbot support ticket but haven't received a response yet after 24hours.
Seems like the 5v switching regulator on the Main Board is outputting 9v instead of 5v.
All 5v test points on the board measures 8.9v including the botsteps. ( stepper controller ).
I think this is the reason why the ATMega1280 chip is too hot to touch.
Do you think the board is fried?
Read the ATmega specs in the PDF.
If the board works after such abuse, it would be a miracle... call the Vatican.
And buy a lottery ticket.
Sorry to hear about your issues, William. Not the sort of fireworks you wanted for your July 4 birthday...
Maybe a good chance to upgrade from the Arduino Mega1280 to the Mega 2560 ? ;-)
Based on Leon's recommendation, I've used ChipQuik to remove smt chips successful. Leon, was right. the stuff works great.
I'm betting replacing the chip would cost less than the whole board.
BTW. I don't know of a Propeller replacement for this board but there is a CNC control object for the Propeller. I'm currently working on getting my new CNC machine (router) hooked up to a Prop.
Is this a common issue in 4430 switching regulators?
