Video Test — Parallax Forums
Video Test
ercoerco Posts: 20,263
edited 2013-07-12 20:57 in General Discussion
Why won't this embed?
    edited 2013-07-09 22:34
    Why won't what embed? I tried editing your post just to see what you had entered, and I did not see any [video] tags or any other links to content.
    edited 2013-07-10 01:34
    What type of editor is your preference set?
    You need to use the WYSIWYG editor to use the "insert video" button. If you're using the basic editor then you need to use tags as Phil suggested.
    edited 2013-07-12 20:12
    Thanks for the replies, guys. I had something that wouldn't embed somewhere else and I came here to test it. Turns out it worked fine here, but I deleted it since it wasn't terribly interesting. Guess I should have deleted the whole post! :)
    edited 2013-07-12 20:36
    Ah, but you can't delete the first post of a thread.
    It's nice that you explained yourself, I had just assumed you were a forum noob.
    BTW, Welcome to the forum.
    Use the "old embed code" from You Tube, if that was your source. Last time I put one here, that is what worked.
