SimpleIDE IR
Does anyone have an example/test program for Simple IDE to use a remote control with a Parallax IR setup? My Wild Thumper will be here tomorrow and although I have written code to make it work using a light sensor, I would really like to start out using a remote control first. I have the SPIN objects but I kind of wanted to code it all using Simple IDE.
If you have IR code written in PASM, you can include the .spin file in the SimpleIDE project and translate the interface functions from SPIN to C.
EDIT: Yes that is supposed to be like that - I have no clue why.
the waitcnt statement from a 100th of a second to a 10th of a second it will display better with SimpleIDE's serial terminal.
