I've finally decided to pull the plug on an old project & will not have a need for these props. I'll just keep about 20+ for my use. Please make me an offer.
I reckon I'll just post the pix & moreover, I've not perform a physical stock-count for sometime now. Actually, I have 3 full trays (160/tray) of these => 480pcs.
That's a lotta Propellers! I'm just getting up to speed on the propeller, but I anticipate using a lot of them over the next few years - How much of a discount from list might we be talking about for a tray of these? :-)
Let me know too. I might be interested in the lot (of course, less the number that Xanatos wants), for expanding the Big Brain. But I don't have a clue on how to solder these as they won't work on a breadboard, or is there a breadboard kit somewhere to make it possible? Is there also a generic soldering service for these chips to pcbs? At some point I may need to customize a pcb and populate lots of these.
Thanks Humanoido. Xanatos passed this time. I'll send you a PM shortly.
I did started a design, OctaProp, that has 9 x props on-board. Still in the mist of board layout on the 6th prop & had to place it on the back-burner for a while till I completed an urgent assignment. If you think it falls inline with your idea, I'll let you know once I gets the chance to complete it.
Thanks Humanoido. Xanatos passed this time. I'll send you a PM shortly. I did started a design, OctaProp, that has 9 x props on-board. Still in the mist of board layout on the 6th prop & had to place it on the back-burner for a while till I completed an urgent assignment. If you think it falls inline with your idea, I'll let you know once I gets the chance to complete it. Cheers K.
Thanks K. After reviewing the form factor for this chip, I also will need to decline the offer. Currently the Big Brain uses the P8X32A-D40 DIP solution which is a "plug n' play" chip that breadboards and is removable. Unfortunately the P8X32A-Q44 SMT will not fit that configuration.
Cheers
K.
Pricing these now at USD 6 each. 1 free for every 10 pcs purchased.
Are you selling by the tray?
He doesn't want to post the bulk prices. You can send him a PM for a quote for larger orders.
PM me if you're interested in getting a tray (160pcs).
