pov timing question
I'm attempting to build a pov clock. Right now i'm only trying to make a simple smiley face with one spinning led. I was hoping someone could take a look at my code to find a timing problem. The led will do random things for around a minute or so then work when I only try a smile and one eye, when I add the second eye it all goes random. Any suggestions would be appreciated. Thanks! (there are percent signs where they need to be in the code, they wont display correctly on this forum post)
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
var
long start_time
long end_time
long cycle
long piece
'hall effect is high, magnet makes it low
pub circle
dira[0..4]~~
start_time:=end_time:=cycle:=piece:=0
repeat
waitpeq(%100000000000, |< 11, 0) 'wait for high hall sensor
waitpeq(%000000000000, |< 11, 0) 'wait for low hall sensor
end_time:=cnt '
cycle:=end_time-start_time 'figure time for one revolution
start_time:=cnt 'piece is one degree resolution of 360 degrees
piece:=cycle/360
outa:= %100 'turn on red led
waitcnt(piece*80+cnt) 'leave on for 80 pieces of circle
outa:=%0000 'turn off led
waitcnt(piece*80+cnt) 'go around circle 80 pieces
outa:= %100 'turn on led
waitcnt(piece*20+cnt) 'leave on 20 pieces
waitcnt(piece*40+cnt) 'go around circle 40 pieces
outa:=%100 'turn on led
outa:=%0000 'turn off until beginning of loop
By "Random" do you mean blinky spots, or solid arcs/circles?
One thing? I see where you pick up end_time := cnt.
But start_time is assigned zero?
What's the cnt when that happens? And happens again the next time?
I was doing a POV with a QuickStart on the ceiling fan but never found an easy way to sync it.
(details of you Hall circuit would be sweet!)
So I thought I'd use IR Remote control to "adjust" timing.
It has possibilities, but a hard index would be the way to go.
If you get ANY recognizable pattern the speed is pretty close.
But might "roll" slowly.
CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 'spinning p.o.v. project 'p0 through p 29 are r.g.b leds 'p 30 is hall effect sensor 'p 31 is i.r receiver var long start_time long end_time long cycle long piece pub grid dira[0..29]~~ waitpeq(%0000000000000000000000000000000,|<30,0) 'hall sensor for lap time start_time:=cnt repeat waitpeq(%0000000000000000000000000000000,|<30,0) end_time:=cnt 'calculate lap time cycle:=end_time-start_time ' start_time:=end_time ' piece:=cycle/60 'divide lap by 60 outa[0..29]~~ 'lights on for one third of a lap waitcnt(piece*20) outa~
