Solar power gimmick?
ratronic
Searching thru eBay for 100W solar panels I came across these Grid tie inverters. These seem plug & play, you just wire up your solar array then plug the inverter into an existing outlet. Since I am entirely ignorant when it comes to solar has anyone here had experience using these?
What I would stress as a rule of thumb, make sure that the grid tie unit is rated for at least twice your input wattage. Also make sure that they are running in a cool place and don't take on a lot of external heat. I had a unit in the attic and it could not keep up with the attic heat and eventually died a slow death.
Another thing, I would avoid a large grid tie unit as opposed to several smaller grid tie units. Only because if you have a failure, it's not a complete failure, and it's easier to replace individual units.
reduce my carbon foot print and maybe save some money on the electric bill.
And I'm guessing before attaching anything to the house power input, the local power company would need to be involved?
"And I'm guessing before attaching anything to the house power input, the local power company would need to be involved?" - As long as you are not generating more than the power company is supplying it makes things much easier. The only thing I had to do was contact a licensed Electrician to inspect my connection. If I had to do over, I would pay someone to install a secondary breakout panel that would be strictly dedicated to a Solar interface.
"If you generate enough power your meter will run backwards and the power company will send you a check" - Once you reach that point the rules change and there is a lot more involved in getting that setup properly. Some states and power companies have very specific rules you must follow before getting paid back.
