Stepper detent torque when half-stepping
I have a basic question about stepper detent torque and half-stepping. Is it the case that there's no detent torque holding the rotor at the half-step points? I.e., when the coils are deenergized, the rotor will tend to slip to the full-step position?
My intuition tells me that half-step and other micro-step detents are something less than full step detents.
Have you noticed that without any power a stepper motor will seek positions of detent based on the physical magnets? I presumed these are the full step detents.
Reference video:
http://www.youtube.com/watch?v=dmk6zIkj7WM
http://www.youtube.com/watch?v=bngx2dKl5jU
That is why you need to use a stepper driver IC that after a initial allowed inrush current holds it at a fixed level.
You may need to install ~0.2 Ohm current sense resistors etc.
how many wires are on each motor?
The cogging torque on any kind of permanent magnet motor will want to rotate the output shaft when unpowered where it can overcome friction and the other forces present.
This has nothing to do with how much torque is generated while powered. It does effect torque ripple while commutating, however. A motor that has been built not to cog will spin at a more consistent velocity at any speed with a fixed load.
