Parallax Omron 12A SPDT Relay question. Coiuld work using 5 Volts instead of 12 V.
Hi,
The Omron 12A SPDT Relay coil works with 12 volts
but I am posting to know if it can work with 5 volts.
Parallax link:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/relay/List/0/SortField/4/ProductID/656/Default.aspx
Thanks.
Parallax link:
Thanks.
The datasheet indicates the "Must Operate Voltage" is 75% of the rated voltage.
That would put the minimum at around 9 volts.
Datasheets are your friend.
Even if you find one that may work at low voltage that still isn't a good idea.
With low voltage the contacts will be closing slowly and depending on the application cause arch damage to the contact.
If you want to operate at 5V get a relay that has a 5V coil.
Duane J
Use a 2n2222 transistor and 12 volt or a bit over 12 volts to drive the coil.
I use 12 volt relays by preference. There are a lot of good ones with 10 amps or 12 amps capacity.
5 volt relays tend to NOT go up that high in switching capacity. I find them rather dubious as I like to switch 120VAC with durable relays. I also use the ones that have sockets to wire the 120VAC safely on a DIN rail.
http://www.ebay.com/itm/1pc-New-1-Channel-Relay-Module-Shield-5V-For-Arduino-ARM-PIC-AVR-DSP-Electronic-/140908985674?pt=LH_DefaultDomain_0&hash=item20ced47d4a#ht_4687wt_849
But whoa up there, you didn't say what you were trying to do with a relay and the scary part is that you don't even have anything higher than 5V. Have you considered just using a MOSFET or if you are switching mains voltages how about an SSR?
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/400-00052Datasheet.pdf
RELAY-ted story: EG has 12V, 20 A (!) SPST relays on sale for 99 cents: http://www.goldmine-elec-products.com/prodinfo.asp?number=G18820
