A simple RC platform, approximately 24" x 24", capable of moving 100 lbs. on sand....
I need some help with this idea. Like the subject says I need a platform 24" x 24" capable of moving 100 pounds on sand. Max speed needed is 3.5 - 5 mph. Frame will need to be built out of wood probably using 2x4s. Maybe use something like this for the tire: http://www.northerntool.com/shop/tools/product_200331323_200331323 Idea is to have four tires and each side will be indipendently controlled. I.E. to turn you could reverse the left side tires and forward the right side. I'm starting from scratch and don't really have any idea where to start.
Welcome to the forums!
How much do have to spend?
The QuadRover will pull that load @ $5,000. Unfortunately, they are no longer available.
http://www.youtube.com/watch?v=j1GK00oe170
Gas Powered?
Battery Powered?.
Thanks for the welcome!
I would like it to be as cheap and simple as possible and still accomplish the task. This is just going to be a platform for me to play around and have fun with so I certainty don't want to break the bank.
It definitely needs to be battery operated.
The TX/RX will be Spektrum 5.4ghz.
The other option, if it would be easier, would be rigging this to be RC drivable (http://www.northerntool.com/shop/tools/product_200411313_200411313). I'm ok with whichever would be easier. With the wagon all I would need is a motor to modulate the pivot attached to the front axle and the motor(s) for the drive wheels in the rear.
I remember his avatar had a cat in the corner with red eyes.
http://www.ebay.com/itm/Pair-Quickie-Sunrise-Medical-Wheelchair-Power-Chair-Motors-and-Wheels-/111069297657?pt=LH_DefaultDomain_0&hash=item19dc3efbf9
They are typically about $150-$200 per set though.
They come with brakes that you can remove, and are 24V powered.
This is just a wheelchair base, a sabertooth 2x25 and a cheap R/C receiver. It's being controller with a Specktrum DX transmitter.
Rick
The current tires should be changed because they are for inside use. You want something with outdoor tread.
This first test/prototype is currently sitting in my spare room and I am now onto designing the actual Project ATLaS. Below is a photo of where I am so far..
falcon
