DIY Spinneret? — Parallax Forums
DIY Spinneret?
blittledblittled Posts: 697
edited 2013-06-18 10:24 in Accessories
I have an old Gadget Gangster Platform with SD card and MGH's add on that permits the GG to use Arduino Shields. I just noticed that Radio Shack has the SeeedStudio Wiznet shield V1.0 which uses the same chip as the Spinneret. I realize the pin outs will be different but other than that would it be compatible with the Spinneret?
  • Mike GMike G Posts: 2,702
    edited 2013-06-18 10:08
    Are you asking if the Spinneret firmware can be used with a SeeedStudio Wiznet shield V1.0 by updating PIN I/O? I suppose it would work - I don't see why not.
    The Spinneret schematics, firmware, and W5100 docs are openly published. You'll have to do a little research to verify.
  • blittledblittled Posts: 697
    Yes that's what I'm asking. Thanks for the info. I'm just brainstorming. I got a $10 off coupon from RS and it'll make the shield $9.95. Something I can't pass up since I have MGH's add on board and a couple of Arduino pin compatible micro controller boards.
