DIY Spinneret?
I have an old Gadget Gangster Platform with SD card and MGH's add on that permits the GG to use Arduino Shields. I just noticed that Radio Shack has the SeeedStudio Wiznet shield V1.0 which uses the same chip as the Spinneret. I realize the pin outs will be different but other than that would it be compatible with the Spinneret?
The Spinneret schematics, firmware, and W5100 docs are openly published. You'll have to do a little research to verify.
