Largest size Variable Array the Propeller can handle?
xanatos
I'm using i2cdriver from the OBEX and I see this line:
I2C.Read_page(I2C#EEPROM,$0123,@Array,500) Read 500 bytes from an EEPROM starting at address $0123 and store each byte in Array
This would be useful to me... and it got me wondering how big that array can be... could it be 1280 by any chance? And how can this information be determined by someone such as myself who doesn't even know what to look at to figure this out :-)
Dave
Dave
If you have only a little bit of code you can define a byte array of about 32700 bytes.
The compiler will tell you when code+data not fits in hubram. So just try how far you can go before you get an error. Or press F8 (view info) and you get an Info-window which tells you how many longs are free. One long = 4 bytes.
1280 bytes should not be a problem, if you not have some big video buffers reserved.
Andy
Dave
