Numbers.spin: Leading space always for sign; removal?
I'm working with Numbers.spin from the OBEX. It does everything great, but whether you want te number output signed, or not, it always leaves a leading space for that sign. You can hide the sign character so it just uses a space, otherwise it will display the + or - character.
I've tried removing references to the SChar (Sign Character) within the BCXToText method and it still leaves in that leading space... does anyone have any idea how I might:
1: Edit Numbers.spin so it doesn't even leave a space for the sign, or
2: Is there a version in Spin of a find & replace in a string that I could use to just pull that leading space out, or
3: Is there a way in Spin to just display the last X characters of a given string, or alternately to NOT display just the first character of said string?
There is a manual formatting function in Numbers but even that only gives you the option of displaying or not, the sign symbol, but it only hides it - it doesn't remove its holding space.
Numbers.spin attached for reference.
Dave
Dave
Thanks Phil!
Dave
SendString( ..., Num.ToStr( value, Num#DEC)+1)
Thanks again,
Dave
