Employee time clock
Hi, Ive got a few programmable card which Parallex sells and prop and pickaxe. Cards should be easy to program due to the objects provided. The thing i am wondering is it is not god to hold the informatin in the cards as employees are likly to lose them sooner or later. So the issue is is storing the times in the little black box and then transferring that data to the office computer.
My first thought is that i might be able to use a usb stick, I hate to say it but a couple of farm employees are writing down hours down that we know are not right, up to 18 hours extra in 1 week was the worst case.
In this day and age here in Queensland it is troublesome to say the least to accuse someone of lying. They can g o to the Fair Work department and create hell. Employees have more rights than employers it seems.
Anyway id like to try this just as an experiment. I have all the parts. Just not sure how its all going to work. Ill make a start and then post problems. wish me luck
[h=1]Thread: [Finished Project] RFID Employee Time Clock (Version 3)[/h]http://forums.parallax.com/showthread.php/130902
As are keyboards with stuck capital letters!
I must hole heartedly agree that was not well thought out having the card store the data. I did have a reason, that being the ease of transfering the data to a PC and i had 6 smart cards to use !
Check this out, i searched ebay 5 minutes ago, not bad for $85 dollars. http://www.ebay.com.au/itm/2-8-Color-TFT-Fingerprint-Time-Clock-Attendance-System-Employee-Entry-Biometric-/280953392464?pt=AU_Home_Personal_Security&hash=item416a208d50&_uhb=1
What do you think ?
Per localroger, quality is hard to gauge. But at that price, buy one and try it. If it works for your application, buy a backup unit or two ASAP. Heck, Sparkfun charges $50 just for a standalone fingerprint reader module: https://www.sparkfun.com/products/11792 IIRC, Duane Degn has & likes that module.
Another Britishism of which I am unaware. Bollix me!
http://www.phrases.org.uk/meanings/293200.html
What about forgetting RFID and all cards and just using a keypad ?
Goodnight, its just gone midnight. :thumb:
iButton=cheap electronic key. Requires brief contact to read. http://www.ebay.com/itm/DS1990A-F5-TM-Card-iButton-Tag-with-wall-mounted-holder-5pcs-Red-/260963981538?pt=LH_DefaultDomain_0&hash=item3cc2aa58e2#ht_1461wt_1146
Did you look at that $56 turnkey fingerprint timeclock? If it works for you, it's your most secure option.
Their use was in skilled nursing facilities with 50 to 70 employees working 3 shifts, 24/7. We had a housekeeper clean the scanner once each shift. All in all, despite the occasional hiccup, "most everyone" liked the system and it elimimated a lot of punch errors.
Amanda
True, and it also has the advantage of not having a tag to loose. Definitely the better choice if the scanner works reliably.
just wanted to say that here in Brisbane Australia the buses here use rfid cards , they are called go cards. You transfer any amout amount of money on your GOCARD and you swipe on and off buses. This 'takes' the money of your rfid card and also the bus computer hold that amount, then when the bus gets near certain wifi spots the money is 'taken' to a central computer.
