jm_etimer an pause
Ltech
Hello
I try to freeze the jm_etimer using et.Hold.
Nothing happens ?
e.clear works.
Nothing happens ?
e.clear works.
If you run the attached demo in PST you see the clock running (as before). Press a key and the timer will hold; press another and it will resume. Sorry if my old code caused you any inconvenience.
It run fine just now.
I use the timer for sending clocks trough spinneret UDP , set , hold and reset trough Mac program
Strange nobody stumble on this before ?
