Electronic Goldmine Box of IC's.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G19135
Admit it, you wonder what you'd get for five bucks. Fortunately localroger bought one and is willing to spill the chips.
If I was younger with more time to burn it would be an interesting game to see how many of these I could use in a single project.
qty 7 4N35 Opto-Isolator 1 74367AN 2 7445 BCD to decimal decoder-driver 1 74ALS139N 21 74ALSD48N BCD to 7-segment decoder 1 74F04PC 2 74F20 1 74F40N 1 74F86PC 1 74HC125N 3 74HC4040B1 12-bit async binary counter 1 74HCT244 1 74HCT374 1 74HCT541N 1 74LS05P 1 74LS138N 3 to 8 decoder 1 74LS166N 8-bit shift register serial/parallel 3 74LS174N hex D flip-flops 1 74LS175N quad D flip-flops 10 74LS20N dual 4-input NAND gate 3 74LS245N octal bus transceiver 3-state outputs 3 74LS645N octal bus transceiver same as 245 1 74LS670N 4x4 register 3-state outputs 3 74S00N 2 74S04N 1 DS7510N dual line receiver 15 LF353N Dual JFET Op-amp 14 MC1455P1 555 clone --- 84 TotalThe guaranteed value seems to be in the 555 clones and op-amps. Then there's a bit of exotica; I've never seen an actual S-series TTL chip before. And what's with the 4-input NAND gates?
Low Power Schottky where 'Low Power' is relative... It uses less power than the 'S' series...
(There's a reason that the 'S' series is obsolete... )
The HCT stuff, though. Good performance and low power draw.
(The 'T' signifies that it's compatible with both CMOS and 5V TTL logic levels.)
74LS08N
74LS20N 4X
74LS21N
74LS27NDS 4X
74LS32
74LS38N
74LS75N
74LS86AN
74LS109AN
74LS126AN
74LS138N
74LS163AN
74LS166N 10X
74LS173AP 4X
74LS174N 2X
74LS629N
74F04PCQR
74F14N
74F20 2X
74F51N
74F86PC
74S00N
DM74S04N
74S38N
74HC05AP 2X
74HC4040B1 5X
74ALS048N 2X
SN7445 2X
SN7438
SN74160N
SN74367AN
CD4028BCN
MC14040BCP 15X
74 PIECES TOTAL
9934 2X
74F8GPC 2X
74F51N
DM74S04N 3X
DM74ALSO4BN 2X
SN74S00N 3X
SN74S3ON
SN74367AN
SN7438N
SN74LS126AN
SN74LS174N
SN74LS266N
SN74HC05N 2X
20-PIN CHIPS:
74HCT541N 2X
SN74LS373N
SN74LS645N
SN74LS682N
26 chips total. Any rare million dollar gems in my assortment?
