NEWBIE: Analog to Digital Question
Hi All, Today's dumb question is as follows:
The Propeller has more I/O's than I'll ever need for my "hope to be" finished product. So do I need to add IC's for ADC and DAC conversion. All my devices run off 5VDC. If so, does anyone have any circuit examples. I plan on using the Propeller USB project Board as my base.
My project will have the following needs.
4 - ADC Inputs (all reading 0 thru 5 VDC)
4 - TTL Inputs
6 - Outputs to enable relays via LOW level grounding.
Thank you in advance.
4 - TTL Inputs
For TTL inputs, you might be able to get by with 3.3K or 4.7K series resistors to limit the current to under 500uA (R > (5V - (3.3V+0.6V))/500uA = 1.1V/500uA = 2.2K).
For relay switching, you could use a Darlington array (ULN2803A)
I have another question though, another circuit I may need to add will be to drive 12 VDC solenoids. The factory application have 12 VDC running to them at all times and they are triggered with a ground for either simple ON/OFF or PWM. The way I've seen them wired is thru a single Hi Power tin can style transistor. Do you have any thoughts on how I can add this as well.
In the end by what your describing i may be better off creating a "daughter board" with all my compnents that connects to the Prop Board I want to use.
Please give me your thoughts.......... Thanks again.
There's plenty of room on the Project Board for a MCP3204 and a ULN2803A as well as connectors to their inputs and outputs respectively.
