Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Question about this NiMH charging circuit - BQ2002 — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
W9GFO
4,010
2013-06-04 06:32
edited 2013-06-04 08:16
in
General Discussion
I'm building a 5 cell NiMH charger using the TI BQ2002 chip. Can anyone explain what the purpose of Q1 is in this schematic?
68.9K
Tracy Allen
6,667
2013-06-04 07:31
edited 2013-06-04 07:31
Q1 is forward biased only when the DC pin is greater than the battery voltage, and that appears to turn on (or off) the Vcc supply. On charge only when DC supply is greater than battery voltage by at least 0.6V.
W9GFO
4,010
2013-06-04 08:11
edited 2013-06-04 08:11
I don't understand why it would need to do anything with VCC. Is this a means of supplying the BQ2002 with power?
If VCC is coming from a regulated 5V supply what happens when 9V is on the DC pin and the Batt is at 5V?
Mike Green
23,101
2013-06-04 08:12
edited 2013-06-04 08:12
Vcc is supplied by a Zener diode regulator (1N751A) switched on and off by Q1. There's no external source of regulated 5V. Vcc is derived from DC.
W9GFO
4,010
2013-06-04 08:16
Well that makes a difference. Thanks! Didn't realize it was a zener - no squiggles on the line...
Sign In
Register
to comment.
