Question about cog speed
I ran a simple program to check how fast a cog cycles through a program. So I set a cog to repeat a simple upcount. My main cog runs my lcd display and show the count. In 10 seconds I get roughly 270,000 counts. So that cog only seems to be cycling at 27khz. What am I missing hear? If the microcontroller runs at 80mhz whats slowing a single cog down so much? I attached the code below. Theres alot of extra stuff on there. I just removed enough to run this simple test. PUB buttons is the simple count code in its own cog. Thanks
CON _clkmode = xtal1 + pll16x 'Use the PLL to multiple the external clock by 16 _xinfreq = 5_000_000 'An external clock of 5MHz. is used (80MHz. operation) _OUTPUT = 1 'Sets pin to output in DIRA register _INPUT = 0 'Sets pin to input in DIRA register _HIGH = 1 'High=ON=1=3.3v DC _ON = 1 _LOW = 0 'Low=OFF=0=0v DC _OFF = 0 _ENABLE = 1 'Enable (turn on) function/mode _DISABLE = 0 'Disable (turn off) function/mode 'LM9033A LCD _LCD_cs = 15 'LCD chip select _LCD_rst = 14 'LCD reset _LCD_rs = 24 'LCD register select _LCD_sc = 25 'LCD serial clock _LCD_sd = 26 'LCD serial data _LCD_bl = 0 'LCD backlight, note this is inverted output, when on, BL is off because of PNP transistor. 'screen sizing constants for 128 x 96 display _xtiles = 8 'Each time is 16 pixels x 16 pixels _ytiles = 6 'Each tile requires 16 longs _screenSize = (_xtiles * _ytiles * 16) 'Size needed for video memory array '*************************************** ' Misc Definitions '*************************************** mode = 23 'active high up = 22 'active high down = 21 'active high enter = 20 'active high increase = 5 'output decrease = 4 'output on = 11 scram = 18 'active low tb = 19 'active low dpin = 2 'both din and dout of the mcp3208 are connected to this pin on the prop demo board. cpin = 1 'the clock pin of the mcp3208 is connected to this pin on the prop demo board. spin = 3 'the chip select pin of the mcp 3208 is connected to this pin on the prop demo board. '************************************** VAR 'Variables to be located here long VIDEOmemory[_screenSize] long LCDmemory[_screenSize],co2psidisplay,co2psi,pinset,pinset1 long stack[1500],volt,offset,boostoffset,liveboost,liveboostav,count,co2av '*************************************** OBJ LCD : "Brilldea-LM9033A Driver-Ver002.spin" Gr : "graphics.spin" eeprom : "Propeller Eeprom" FD : "FullDuplexSerialPlus.spin" stringObj : "ASCII0_STREngine_1.spin" sensor : "MCP3208.spin" filter : "filter_ma.spin" '*************************************** PUB main | t0 cognew(buttons, @stack[100]) LCD.start(_LCD_cs, _LCD_rst, _LCD_rs, _LCD_sc, _LCD_sd, _LCD_bl) gr.start gr.setup(_xtiles, _ytiles, 0, 0, @VIDEOmemory) LCD.reset LCD.initialize(0, @LCDmemory) LCD.contrast(25) sensor.start(dpin, cpin, spin, 255) offset := sensor.average(6,10)+10 boostoffset := sensor.average(5,10)+10 repeat MainScreen PUB MainScreen |tic '*************************************** volt:= (sensor.average(7,10))/10 gr.clear gr.color(3) gr.textmode(2,2,5,4) gr.width(0) 'gr.text(63,71,@TXTlogo) gr.text(63,70,stringObj.integerToDecimal(count,8)+1) 'used to test gr.finish gr.finish gr.copy(@LCDmemory) gr.finish LCD.screenUpdate(0,@LCDmemory) PUB Buttons repeat ' co2psi:=(sensor.average(6,10)) ' liveboostav:=(sensor.average(5,10)-boostoffset #>0)/36 ' liveboost:=(boostfilter(liveboostav)) ' co2av := filter.ma16(co2psi) count:=count+1 If ina[mode]==1 count:=0 if ina[enter]==1 repeat until ina[enter]==0 pub boostfilter(x_meas):x_ret ''4-sample moving average filter, implemented with recursion. ''Max filter update rate ~13000 samples/sec for 1 cog @ clkfreq=80 ptr &= %00001111 'mask off all but lower four bits sum := sum + x_meas - x_buf16[ptr] x_buf16[ptr] := x_meas x_ret := sum ~> 4 'divide sum by 16 ptr++ DAT '*************************************** TXTlogo byte "Boost Leash",0 TXTco2 byte "Gate",0 TXTcntrl byte "Leash",0 TXTprs byte "Boost Gate",0 TXTlaunch byte "Launch Psi",0 TXTStages byte "Stages?",0 TXTSetup byte "Stage Setup",0 TXTStagez byte "1 2 3 4 5",0 TXTT byte "Time",0 TXTR byte "Rate",0 TXTP byte "PSI",0 TXTpsi byte "psi",0 TXTTEE byte "T",0 TXTPEE byte "C",0 TXTB byte "B",0 TXTset byte "Set",0 TXTlive byte "Live",0 TXTpoint byte ">",0 TXTrpm byte "RPM",0 TXTact byte "Act",0 TXTvolt byte "Volt",0 TXTa byte "A",0 TXTscram byte "Scramble",0 'scramble TXTadd byte "Add",0 'scramble TXTforce byte "Force",0 'scramble x_buf4 long 0,0,0,0 '4-place filter input history buffer x_buf16 long 0,0,0,0,0,0,0,0 '16-place filter input history buffer long 0,0,0,0,0,0,0,0 sum long 0 ptr byte 0
Examples of this include a 4-port serial communications object, a servo motor driver that can handle up to 32 servo motors simultaneously, a combination of a general purpose I2C driver and SD card SPI driver that can handle double buffering, and a fast 32-bit floating point object that handles IEEE floating point including a wide variety of transcendental functions.
That timing loop of yours is doing a lot of work what with using both graphics and an LCD. Could be that writing that in PASm would not be much faster as all the actual time is used in those other objects.
You really need to benchmark whatever it is you need to do fast. Use CNT to get the start and end times of sections of code and don't put any display code within the thing you are timing.
Another neat thing you can do with the Prop is toggle a pin as the loop you are timing goes around. Then you can measure that pin frequency with a scope or frequency counter. Or with a bit of code use another COG to measure the frequency it sees on that pin.
I would want to check if my Spin code is fast enough for the job before wanting to rewrite it in PASM.
On the other hand PASM is not so bad. It's about one of the easiest assembler language I have come across and as it's integrated into Spin in is very easy to use.
Don't despair about Spin's speed. Remember that, in most programs, 90% of the program's execution time is spent in 10% of the code. Spin is ideal for the other 90% of the code. The important thing is that you can't tell ahead of time which is which. You have to build the program and get it to work first, then measure how much execution time is spent doing what, and then optimize it ... converting just those pieces needed into assembly.
The exception, in the case of the Propeller, is when you have highly time-dependent code. Still a lot of that can be done in Spin if it doesn't need too much raw speed.
I thought the programs for my lcd display was slowing things down so I set it to update the display every second to see if the simple repeat count:=count+1 in the other cog would speed
up but it ran at the same speed. Main reason for this testing is that I wanted to use a adc to record a sensor at a high rate but with the whole program it slows way down.
In about 2 weeks a complete development system for PropBasic will be available to download.
Cheers.
I have a copy and I believe it covers the sort of things you are looking for.
Mickster
