Stamp Works experiment #28: Reading voltage with the MC14489. Has anyone done this?
Hello to all.
Ive been plowing through the Stamp Works experiments using the Basic Stamp 2 (BS2-IC) and Im especially interested in Experiment 31 using the MC14489 seven segment LED multiplexer.
At the end of the experiment there is a challenge to go back and do Experiment 28 (reading voltages) using the MC14489 and 0831 ADC with seven segment LEDs for the voltage readout instead of the DEBUG function.
Has anyone done the code for this challenge experiment?
Thanks for any help.
Marty
Marty
I have several articles by Scott Edwards and Jon Williams from N&V which I'm going through, and I've done the experiment in Stamp Works using the MC14489; now it's just a matter of substituting the MC14489/LED combination for the DEBUG function in the voltmeter experiment.
The project I'm working on is a temperature alarm/readout using the LM34/ADC0831 combination with four adjustable alarm points with relay outputs. I have everything working on a bread board using discrete LEDs for the temperature readout at 10 degree F intervals but now I think that a 7-segment LED readout would be much better.
I guess it's just a matter of working on it until I get it right.
Thanks again,
Marty
