for erco - Man builds working car out of wood — Parallax Forums
edited 2013-06-02 02:13 in General Discussion
http://news.yahoo.com/blogs/sideshow/wood-car-build-diy-project-190822009.html
Putting all other do-it-yourself projects to shame, a Hungarian farmer spent the winter building a car made almost entirely of wood.
"I love to work with wood," Istvan Puskas, a 51-year-old from the village of Tiszaors, said in what should be considered the biggest understatement ever.
The frame, axles, gears and even the gas tank—which Puskas fashioned from an old beer barrel—are made of wood. The engine (from a Fiat 126), steering wheel (from an old Mercedes-Benz) and windshield are virtually the only parts that are not.
    edited 2013-05-31 00:56
    The guys at Morgan needs to talk to him...
    edited 2013-05-31 05:35
    Agreed, here is the only proper way to build a car with wood.
    http://en.wikipedia.org/wiki/Morgan_Motor_Company
    The termites and dry rot must have their panache.
  • David BDavid B Posts: 593
    edited 2013-05-31 11:35
    I could argue with that, after having seen this beauty:
    http://www.flickr.com/photos/eagle69er/3069342311/
    http://www.ultimatecarpage.com/car/3859/Hispano-Suiza-H6C-Tulip-Wood-Torpedo.html
    The museum guide told us that the entire body only weighs about 160 pounds!
    edited 2013-06-01 07:26
    Argh.. a natural wood finish... likely varnish. It looks absolutely great in a museum in pristine condition.
    But sunlight, wind, and weather would require refinishing regularly. Have you ever tried to maintain the 'bright work' on a sailboat?
    Transparent polymers all yellow and breakdown in sunlight. I often wonder about the modern car's paint job as they all now have a 'clear coat' over the 'color coat'. You now see strange blushing, crazing, and blemishing. Before you just rubbed off the oxidized paint and waxed.
  • RDL2004RDL2004 Posts: 2,554
    edited 2013-06-01 08:58
    Not completely true. Acrylics and aliphatic polyesters and urethanes have very good resistance to sunlight (UV). I wouldn't be surprised if most problems with modern automotive clearcoats are due to the fact that they are "waterborne" finishes.
    edited 2013-06-01 12:26
    Here in Southern Taiwan, we have vast herds of plastic motor scooters and automobiles.... None do very well in the tropical sun. Clear coat just seems to make it harder to refinish when the time to do so comes.
    But the most interesting phenomena is when an old motor scooter spends its whole life parked outdoors in direct sunlight. It actually rots away from the rays of the sun. It may take 20 or 30 years, but it does disintegrate.
    With varnished wood, any scratch or puncture invites moisture into the wood and it discolors and rots. Generally wood moves as it expands and contracts, so wherever there are right angle corners, the moisture barrier is broken and deterioration begins early. I would have to say it is the substrate as much aa the varnish that causes the maintenance difficulties. A deep, low-viscosity penetrating epoxy is optimal for wood.
    But I still strongly belive that all clear plastic resins eventually yellow as they age.
    edited 2013-06-01 12:59
    The point is that you can't generalize. There are too many different types of polymers in use and they vary greatly in their properties.
    Epoxy is generally not very good for exterior use unless highly stabilized and is rarely used as a wood finish. Classic "varnish" is basically made from cooked vegetable oils. Modern "varnish" is typically alkyd based. Neither are great for exterior use. Your scooters may use some type of ABS plastic which has poor UV resistance if not painted or otherwise protected. Polyethylene and polypropylene are also very quickly degraded by sunlight.
    edited 2013-06-01 22:51
    Pretty sweet, Ron! I'm in Shenzhen China now and just saw this... BUSY here. No Youtube here, but I could see the the Yahoo link you posted, thanks.
    The polychloride vinyl parts of the motor scooters are the first to degrade in sunlight, the painted parts are the last.
    It seems that plastics with carbon black filler last the longest in direct sunlight, while clear plastics have the shortest useful life.
    I do admit that modern clear plastics may not yellow anywhere near as much as their predecessors. But even if the clear coat remains non-yellowing, it does craze and blush in intense sunlight.
