Issue with TSL1401 (line scan camera) monitor program
Hi. I just purchased the Mobo 2p/2pe, along with a line scan camera (TSL1401-DB). It looks really slick, and I am itching to start it up. I downloaded the LoadAVR program, and successfully uploaded the TSL1401DB01.hex hex file. I also downloaded the "TSL1401_monitor.exe" Windows program, but when I try to run this, I see a window flash briefly and then disappear. Could anyone suggest what I need to do to get this monitor program to run? My OS is Windows 7; the monitor program did not specify which versions of Windows it supports. Thank you.
Kevin
Kevin
The monitor program you downloaded from the TSL1401-DB product page (v1.2) is not the current version. Parallax has promised me they would upload the current version (v1.4) soon. In the meantime I have attached that version here. Please let me know whether it solves the problem you are having.
Kevin
