Abstract Data Structure (AN003) question
Hey all,
I'd like to get some input about an object and it's methods. I'm using an array of external objects set up as an abstract data structure as described in http://www.parallaxsemiconductor.com/sites/default/files/appnotes/AN003-AbstractDataStructures-v1.0_1.pdf
My data structure object is very simple:
I'm running 16 of these objects in my top level object. My top level object starts up 4 different cogs, as outlined below.
Cogs 2,3 and 4 do different stuff with the sensor value at different times, and they are all started within the top level object- not by/as different objects. There is a chance that multiple cogs will attempt to read the sensor value at exactly the same time, or read it when it's being written to.
Since the hub does that "round robbin" thing I think this is ok, insofar is preventing memory collisions on the sensor data since it's a single long. (Please correct my if I'm wrong on this point)
But- what about calling the Node[x]._Sensor method simultaneously from different cogs? For example, If cog 2 and 3 both attempt to run temp:=Node[x]._Sensor at the same time, what happens?
I haven't implemented a lock for this method, and I haven't seen any real issues with the sensor data. However, that could simply be because two or more cogs haven't accessed the method as I've described above... yet.
I'm not completely sure how I'd go about testing it thoroughly. Does a lock need to be used to prevent problems here?
Thanks in advance,
Robert
SensorValues.spin ---> Sensor data structure.
CON
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
Var
long Sensor 'Value for attached sensor
Pub Sensor_(Val) 'Sensor Value: WRITES value to variable. (Val)= value to store.
Sensor:=Val
Pub _Sensor 'Sensor Value: READS value of variable. Returns stored value.
return Sensor
Application- runs 4 cogs. 1 cog writes the sensor value, 3 cogs read it.
OBJ
Node[16]: "SensorValues"
pub main
Cog 1 will write the sensor value using Node[x].Sensor_(DataIn[x])
-This cog repeats every 100 ms
-Will cycle through all 16 values
Cog 2,3,4 will read the sensor value using temp:=Node[x]._Sensor where x= the sensor to read
-Cog 2 repeats every second
-Cog 3 repeats every 4 seconds
-Cog 4 repeats on defined input
-Each will cycle through all 16 values
Thanks in advance,
Robert
If your sensor code contained two or more values that were being read or written, then you might have an issue. For example, if you were recording a pressure and temperature value. If both values came from the sensor, and needed to be "together" to be correct, you'd need a lock. Without the lock, you could have one cog writing both values from your sensor, and have another cog read the values while the first was in the middle of writing them. You could get a temperature value from sample #1, but the pressure value from sample #2, so in this case you'd need a lock to properly deal with it.
In the simple case of a single long / word / byte value, you don't need a lock. Calling the same method from multiple cogs is also safe, as each cog will have its own stack for local variable use. If a method makes use of non-local variables, and you call the method on the same object instance from multiple cogs, then you might also have an issue.
Ok, that's what I thought concerning the singular long read and write with regards to collisions.
I don't think I quite understand what you're telling me here:
Are you saying that if my abstract data structure object (SensorValue.spin in the example above) wrote the supplied parameter to a global variable via something like long[global_var] which was defined in the top level object it might be a problem? I'm not intending to do something like that, but I'd like to know what you mean. Sorry, I'm just a tad confused here!
VAR long counter PUB MyMethod( size ) repeat counter from 0 to size ' Do something meaningful hereBy using the counter value in the object, instead of having a local (stack) variable for it, calling this method from two different cogs would be problematic unless each cog had its own copy of the object.
Does that make more sense?
