Help with 1PCS Sound detection sensor module
Hi,
I have this Sound detection module :
http://www.ebay.com/itm/261083086582?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D261083086582%26_rdc%3D1
And this is the .pdf of the main chip:
https://www.fairchildsemi.com/ds/LM/LM393.pdf
I need help to connect this to a Basic Stamp2sx and create a code for this.
Please if someone could help me, Thanks.
Did the board come with documentation? It may need a pullup resistor at the output, because the LM393 pulls low but not actively high. The adjustment probably affects the threshold sound level.
It worked fine, but I had to modify it a bit.
I have some questions, ¿Can it give another type of values other then just 0 and 1? ,if it do,
¿What comands could I use?,
¿Could I use something like SERIN o PULSIN?
Thanks.
Thanks Allen. :thumb:
