Parallax USB Scope (Not Prop Scope) Leads?
rwgast_logicdesign
The other day I got one of the older Parallax USB Scopes, these scopes have been discontinued for a long time. Anyways it is second hand with no leads, I was wondering if anyone knew where leads can be purchased? The scope doesn't use standard coax probes, it uses what look like barrel connectors found on power adapters. I could make my own but that is kind of shoddy, I could also convert the thing to BNC probes but i'm not sure if this scope is set up for standard impedance value found in common BNC probes.
Guess you could get some brand new ones...and a backup O'scope.
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=111037065061
Or wait till Tuesday and call Parallax.
The barrel connectors are about 4.0 mm o.d. x 8.0 mm long. I don't think 4 mm dia. is a common size. I couldn't get a good measurement on the center pin. It's pretty small, not the usual 2.1 mm. The meter probes I was using are about 1.95 mm dia. and they wouldn't fit inside the barrel connector, so probably 1.5 or 1.8 mm.
