dual band antennas
xanadu
If I had a "regular" dipole whip antenna with no markings would there be a way to figure out if it is 2.4ghz, 5.8ghz or dual? I can measure signal strength but it doesn't seem to help, or the antenna is dual band. I have a few of these and they got mixed up with other access point antennas and I don't want to just guess which went where. Thanks.
I have a similar problem with some 900MHz and 2.4GHz antennas. They both look the same but I don't know which antenna is which. I suppose I could attempt some sort of range check.
Imagine a vertical dipole formed from a length of coax by rolling the shield back onto the jacket by 1/4 wave, thus exposing 1/4 wave of center conductor. Of course, that's not how they're really made, and everything is molded into plastic or rubber, but it's the electrical equivalent.
