I-5 Bridge Collapse at Skait River In Wa. State
A little over an hour ago we had breaking news that the Skagit River I-5 Bridge collapsed. Rescue efforts are underway. News shows a couple cars in the water. Major through fare north and south bound.
Then the Hood Canal bridge, which sank in a storm:
Next came the I-90 bridge over Lake Washington:
Now this:
If you're coming to visit Washington, watch out for our bridges!
Lawson
P.S. more pictures and what the bridge use to look like.
That seems to be the case here too. Somebody is going to lose their trucker's license and maybe a trucking company is going out of business as well.
Heavily traveled section of I-95 corridor between New York and Boston.
I'd love to hear the weasel word explanation from the company, probably something like "well, our real job is just to merely alert drivers of your presence, those engineers should have measured every overpass beforehand just in case we failed to."
Most notably, a coworker had a refinery stack project "extended" for another year because it was run into the top of an overpass. Because the pilot car "got stuck in traffic".
http://mynorthwest.com/11/2281588/Trucker-with-wide-load-likely-cut-off-at-Skagit-bridge
http://en.wikipedia.org/wiki/The_Iron_Bridge
Here in Oklahoma we try to take the bridges out before they can cause a real problem to make way for an improved bridge if necessary
http://www.youtube.com/watch?feature=player_embedded&v=MYN0JwDQXWU#!
It is entirely up to the driver to make sure the load is not too high. If too high, don't go.
The pilot car driver has no way of measuring height in transit of obstacles and compare them with an excessively high load. He has no way of measuring the load height, and it isn't his job anyway.
In eastern Washington, we had a crane company with one freeway bridge between their yard and the site. Their drivers just didn't check the clearance before they got on the road and the results were that the one and only freeway overpass got in three times successively over a period of years.
At least this is not a failure of an interstate bridge due to improper inspection or maintenance. You can't keep foolish people from jumping in a vehicle without thinking what they are doing, but you can make sure the bridges are safe for normal traffic.
Freeway overpasses get knocked out all the time, it is much rarer to take out an interstate bridge with a high load.
If they really needed to drive down a center lane and were forced out of it, there is a good case that they didn't have adequate escort and traffic control. One pilot car can do only so much on a 4 lane interstate.
Also, the time that they were on the bridge may have been all wrong.
Edit: Here it is: http://www.foxnews.com/us/2013/05/25/state-report-shows-5-bridge-had-gouges-impact-damage-months-ago/
Bridges are for sissies.
We need to get this country back to the way it was before all this bridge-building future-oriented nonsense started to disrupt the way things were meant to be.
It seems it was designed pretty well. Why so? It failed slowly.
One cannot afford to make all megastructures bulletproof, but when failure does occur, a slow one is better. People have time to get out of the way.
I had to learn truss design for Statics and Strenghts of Materials in university. Each member has a role as a tensile or compresive member. The failure of one simply upsets the static stabilty and it all comes apart.
For comparision, a car might weigh all of 2 tons, but an 18 wheel semi is rated to max out at 80 tons, unless it is a special heavy load. 80 tons is a more to whack a bridge with.
Many pilot cars have "high poles" for just that purpose.
Ultimately it is the driver's responsibility, he should have been in the center lane well before approaching the bridge. There is really no good excuse.
Also, an 18 wheeler maxes out at 40 tons not 80.
Those are some really nice, neat, explosive cuts on that bridge. Professional demolition is pretty cool.
Jeff
Corrected, 40 tons = 80 thousand pounds.
These bridges do stand up well to taking direct hits from all sorts of high speed automobile collisions, but a vehicle that is 20x the autos mass just is too much.
Driving an 18 wheeler is very serious business... always will be. Part of the problem is that each state has its own licensing examination standards for these big trucks. I had an Oregon Driver's License that permitted me to drive 18 wheelers and it was issued with just an added written exam. I never drove one, but I legally could throughout the USA.
The Pacific North-west is full of kamakazi log truck drivers that just want to pull as many loads as they can in a day.
That must have been a long time ago. When I got my first commercial license back in the '80s you had to be 21 to drive interstate. In the early '90s they switched to calling it a CDL. All states must meet federal standards for knowledge and skills tests. I can still legally drive an 18 (or more) wheeler, just in case. Not so many log trucks here in the metro area, lot of container haulers though.
The world has changed... keeps changing as well.
As the Chinese goes, "The roadway is like a tiger's mouth." I guess that hasn't changed.
