ExpressPCB- does anyone here use them?
Hey All,
I'm just wondering if any of you use ExpressPCB for having boards made up? I've been using them and the boards have been fine. The software is pretty simple to use but limited. Any thoughts/suggestions on a better solution for getting prototype boards made would be much appreciated. Although, I'd prefer to not have to spend money on software to do it. IF that's even possible!
Thanks in advance
Robert
Thanks in advance
Robert
http://www.diptrace.com/download.php
oshpark.com in USA for 3-9 boards (cheap for smaller boards).
diptrace gerbers work just fine (copper layers inside zipfile should just be called 'top' & 'bottom')
You just export gerbers and N/C drill files, zip 'em up and submit them to oshpark like Tony says. It's pretty dang cool getting PCBs you designed back from them.
I like Kicad because it doesn't have any limitations or costs, it seems like it was built by a software team (so things make sense), it's easy to use, and it's cross platform. It's also very well supported and actively developed (I run the Adam Wolf daily build).
Hear hear!
I paid $125 some years back for the student version of Eagle which allows boards up to 100x160mm (Eurocard size) and have use a number of fab houses in China. More recently I've been using http://www.seeedstudio.com/depot/fusion-pcb-service-2-layers-p-835.html $9.90 for ten boards at 5x5cm. That is less than $1 per board, or approx 25c per square inch. I think if you order over $50 there is free shipping. So I've been redesigning all my boards so there are lots of little boards connected with headers rather than one big board. eg a regulator board, an SD card board, a serial board. And at 5x5cm that means you can use the free version of Eagle.
Only catch with Seeed - at those prices and with standard shipping, it can be 3-4 weeks for boards to arrive.
I also wrote a whole bunch of tutorials for newbies on Kicad just in case anyone needs them:
http://tymkrs.tumblr.com/archive
August 28 - Sept 5 2012 for basics on KiCad (I actually walk through my propeller heart led project here)
March 24 - 31st 2013 is where I go through some of the steps but for a different board.
http://tymkrs.tumblr.com/post/46166700270/kicad-brd-files-gerber-files-for-oshpark-service is where I show how to go from kicad files to something that oshpark's system recognizes. It's pretty easy!
Addie
prototype pcb assembly services
