I HAVE A BUG!!! But I dont know why. — Parallax Forums
TCTC Posts: 1,019
edited 2013-05-21 03:47 in Propeller 1
Hello all,
My 3D printer project is coming along real nice, but I have a bug and I don’t know why. I am trying to add A PWM controlled fan to it. But when I add the “start” for the PWM my display goes nuts. There are 2 pictures I have added, one is with
PWM.start(15)
Commented out.
The other picture is when the comment is removed. Other than the display not showing what it should be everything works. I can turn on, and off the fan and adjust the speed from the host software.
Thanks for any input
TC
    edited 2013-05-19 16:46
    Does the same thing happen when the PWM object is started but the fan isn't connected?
  • TCTC Posts: 1,019
    edited 2013-05-19 16:57
    kuroneko wrote: »
    No it does not. Did not think of that. Dose that mean i have noise being injected back into the prop?
    edited 2013-05-19 20:28
    TC wrote: »
    ... Dose that mean i have noise being injected back into the prop?
    I wonder if changing the frequency of your PWM might help? Perhaps you are hitting some sort of resonant frequency that is amping up the motor noise in your other circuits.
    edited 2013-05-19 21:02
    This is probably a ground bounce problem. What are you using to drive your fan, and where do the power leads for it get connected to your circuit?
  • TCTC Posts: 1,019
    edited 2013-05-20 14:38
    I tryed that, it works but I have no speed control.
  • TCTC Posts: 1,019
    edited 2013-05-20 14:42
    I am using a ULN2003 to drive a small PC computer fan. I am using a breadboard so the ground is tied to the prop. bt the 12V comes from a 2A power brick, that also powers my 5V, and 3.3V DC-DC converters.
    edited 2013-05-20 15:10
    What is the ground return from the 12V supply connect to first on your breadboard?
  • TCTC Posts: 1,019
    edited 2013-05-20 16:02
    The ULN2003 would be at the end of the line. I am going to try giving it its own ground path, and see if that helps.
  • TCTC Posts: 1,019
    edited 2013-05-20 16:08
    That did it!!! Thank you everyone for your help.
    edited 2013-05-20 16:39
    'Glad you figured it out, TC!
    edited 2013-05-20 20:46
    TC wrote: »
    I'm just curious - what sort of fan motor is this? I would think that for most fan motors, only the duty cycle would affect the speed.
  • TCTC Posts: 1,019
    It is a standard PC computer fan. if I raise the frequency, I get a squeel from the fan. if i lower the frequency the fan hits top speed at around 50%.
