Diffrent outcome each time
Im messing around with a servo and i get a different outcome each time.
If you look at the code provided you can see at the end of "Pub demo" position is set to 125 (this is centered)
I load the code into the eeprom with F11. when the code is executed after being loaded it will sometimes snap back into place (position 125) and other times not. (after pressing reset)
Using the prop plug, and a micro servo
