Question to Parallax support regarding Quickstart Board — Parallax Forums
skylightskylight Posts: 1,915
edited 2013-05-17 14:03 in Propeller 1
To accomodate the quickstart into a small project box I am going to have to grind away parts of the board using a steady hand and my trusty dremel in order to allow the board to fit between the circular plastic posts that the screws to close the box go through.
the places where the posts go are marked with yellow circles below:
Looking through a loupe I noticed a via top left of the board above what I think is a capacitor, I will need to grind away approximately half of the via but still leave the trace that goes to the top of the capacitor.
The problem that i'm worried about is that looking at the top and bottom of the board at the via there are no visible traces apart from the one that connects to the capacitor, this lead me to now believe that the board is a multi layer sandwich and the traces are inside the board, this has worried me that I may destroy any hidden trace within the board at the vias location or indeed at the other points where I need to grind the board away.
If I grind away part of the plastic posts of the box without exposing the screws I may have a small play in how much pcb I need to grind away.
The question is will removing the board below the yellow circles do any damage or will the quickstart still work ok?
