Need code suggestions for "colorful" VGA output demo
WBA Consulting
I am setting up a test jig where I need to generate a VGA signal that allows for an easy way to ensure all connections are made properly. I need a simple VGA demo that will utilize at least 16 colors. I can use Chip's VGA demo code that shipped with the Propeller Demo Board, but I was hoping somebody would have something else to suggest. Maybe some sprites jumping around the screen?
Or full screen pixel scroll ... http://forums.parallax.com/showthread.php/136617-FYI-Yet-another-50-column-VGA-text-driver-(single-cog)?p=1127190&viewfull=1#post1127190
Do you happen to know how many cogs the bouncing ball code takes up?
EDIT: I re-read the thread and caught that it takes 5 cogs. Since the KISS WAV player takes only 1 cog, I should be set. Thanks again!
I am still using the KISS WAV player, but now I am using the 640x480 Tile Map driver from Kye and just throwing some colored boxes in basic test patterns. My first draft of combined code works excellent. It simply displays a title, starts a loop of three WAV files (left, right, stereo), and runs through two different test pattern loops. Works very well for my need. I will post the finished setup as a project once it is moved off of the Quickstart/QS HIB setup. (if the touchpads on the QS are touched during playback, it wreaks havoc on the WAV player)
