Aluminyze — Parallax Forums
Aluminyze
xanaduxanadu Posts: 3,347
edited 2013-05-16 01:06 in General Discussion
This would make an awesome gift (PM me for my shipping address), or just a really cool way to display art for your shop/office.
http://aluminyze.com
Local company here in north county SD, really cool process and not expensive. When the print is done you can drill it, etc and LEDs or standoffs and protoboards.
Anyone down for an art contest?
    edited 2013-05-15 12:00
    I wonder if they mean aluminise?
    No good anyway as their "start aluminyzing" button goes to a page that never materializes.
    edited 2013-05-15 12:30
    xanadu wrote: »
    Youch!! Not at those prices. I've used metalic papers before for my photographs wchi gives a very unique effect. It looks like this could be interesting to play with using the silver backing. Too rich for my blood to experiment with.
    edited 2013-05-15 13:00
    Yep, looks like "plywoodyzing" for me.
  • Prophead100Prophead100 Posts: 192
    edited 2013-05-15 15:19
    This would be interesting to use for a custom robot body if it was stiff enough.
    edited 2013-05-15 15:55
    Heater. wrote: »
    +1 :)
  • PliersPliers Posts: 280
    edited 2013-05-15 16:00
    I looks to me like they are mounting a photograph to sheet of aluminium.
    What do you think they mean by "infused into a sheet of aluminum,"
    edited 2013-05-15 16:07
    Could be they have a cunning process to anodize the aluminium plate and then print the picture into the resulting oxide layer. The dye could literally "infuse" into the surface.
    http://en.wikipedia.org/wiki/Anodizing
    edited 2013-05-15 16:12
    Well what do you know?
    You just have to get hold of the right printer: http://www.directcolorsystems.com/printer-applications/anodized-printing.php
    edited 2013-05-15 16:22
    That is very ironic. We have a DURA JET at my day job. [h=2][/h]
  • xanaduxanadu Posts: 3,347
    edited 2013-05-15 17:39
    It is printed onto the metal, they were explaining it but I was too busy not paying attention. The samples I looked at felt really nice so I got an 8x10 for $30 which I thought was reasonable to make something really cool.
    Plywood art sounds interesting. I need to do something artistic with electronics but also want it to be unique.
    edited 2013-05-16 00:56
    Every time I think of anything remotely artistic LEDs creep into my mind and poof I'm back to electronics and micro-controllers. In this case plywood and LEDs came to mind.
    Apparently others also have this problem:
    http:// http://www.projectione.com/plylight/
    http://thecolorofthin.gs/post/25418889588/build-details-for-the-aurora-led-wall
    http://www.asylum.com/2009/08/26/sexy-led-lighting-birthed-from-homely-plywood/
    It's hard to be unique now a days.
    Imagine this if you will. Get a nice high resolution sunset just when the stars start to shine. Print it to that aluminum place small enough so it looks really clean. Poke small holes where the stars are, say 10 of them. Put white LEDs behind like 6 of the holes, and for the other four put RGB leds run by a prop and make them twinkle.
    I made a RGB LED twinkle by accident, I might fix this code up and document it and put it in projects.
    This code is for one test LED, the LED I'd use would be very small, SMT possibly. The reason the intensity is different between the colors is I used the same value resistor on all of the RGB LED pins. It looks cool. I'd add in lots of random fluctuation and all four twinkle LEDs would twinkle differently as well.
    CON
     _clkmode = xtal1 + pll16x
     _xinfreq = 5_000_000
     RLED = 2    'Red LED Pin
     GLED = 1    'Green LED Pin
     BLED = 0    'Blue LED Pin
    VAR
     long RLEDi
     long GLEDi
     long BLEDi
     long RLEDs[100]
     long GLEDs[100]
     long BLEDs[100]
    PUB main
     cognew(Red, @RLEDs)
     cognew(Green, @GLEDs)
     cognew(Blue, @BLEDs)
     repeat
       RLEDi := 16          '16
       GLEDi := 58          '55
       BLEDi := 69          '66
    PUB Red
     dira [RLED] := 1
     repeat
       CTRA := %0_0110<<26 + RLED
       FRQA := $7FFF_FFFF/50 * RLEDi
    PUB Green
     dira [GLED] := 1
     repeat
       CTRA := %0_0110<<26 + GLED
       FRQA := $7FFF_FFFF/50 * GLEDi
    PUB Blue
     dira [BLED] := 1
     repeat
       CTRA := %0_0110<<26 + BLED
       FRQA := $7FFF_FFFF/50 * BLEDi
    Anyway I have 2-3 weeks before I get the print :(
