Converting CO2 ppm to mmHg
I am trying to make a carbon dioxide (CO2) intubation device. I understand how to convert the voltage that my CO2 sensor reads into a corresponding CO2 ppm. However, all of the documents that I have read on CO2 intubation refer to CO2 measurements in terms of mmHg. How are ppm and mmHg related? How do I convert from one to the other? That is, how do I get my sensor to output mmHg instead of ppm?
It would be like trying to convert percentage to PSI. I don't think the two are related at all unless I'm missing something important...
Bean
mmHg(CO2) = mmHg(system) * (reading from sensor in ppm) / 1,000,000
I'm trying to remember my gas laws (which I used to teach). I think each molecule of gas contributes equally to the overall pressure (within reason) so there's a 1:1 relationship between PPM and pressure.
So if you had standard pressure then the mmHg of "system" would be 760mmHg.
So in this case:
mmHg(CO2) = (reading from sensor in ppm) * 0.000760
Edit: The above will only work if the parts per million is a mole fraction (same as volume fraction in many cases). If the measurement is ppm mass fraction, then you'd need and additional conversion factor.
If a volume of gas were to consist of 98 % helium and 2% CO2, the amount of pressure the C02 contributes to the "system" pressure of the entire volume within its container miiiiiiiiiight be a little different than, say, a mixture of equal parts helium and CO2 of the the same volume and same "system" pressure.
The equation I gave above would apply to a mole fraction ppm.
