Dumb question (LMM/XMMC) — Parallax Forums
Mark MaraMark Mara Posts: 64
edited 2013-05-14 21:58 in Propeller 1
Hello,
Could someone explain why I get different results running the following 3 line program when complied for XMMC or LMM?
#include <stdio.h>
int main(void)
    printf("print line one\n");
    printf("print line two\n");
    return 0;
LMM works as I would expect, however XMMC displays the last 6 character of the second line. The following screen shots show the SimpleIDE and terminal for each test.
XMMC:
LMM:
Thanks --markM
    edited 2013-05-14 21:37
    I think the reason is one of the models takes a bit longer to startup than the other and the startup delay is similar to the startup time for the terminal program. A similar problem crops up with other displays, eg TV and VGA as they take a little while to get started. Adding a small delay at the beginning of a program tends to fix things.
  • Mark MaraMark Mara Posts: 64
    Thanks. That was it.
    --markM
