QMP+RP2 drivers working in all XMM modes! - Page 3 — Parallax Forums
13»
  • RaymanRayman Posts: 16,037
    edited 2013-05-13 13:04
    Ok, maybe what I just saw was memory corruption due to not having the pullup resistors in the right way then...
  • jazzedjazzed Posts: 11,803
    edited 2013-05-13 13:09
    All working? Great. I'd love to see a video.
    edited 2013-05-13 13:22
    It's exactly the same as the Spin version... There's a video of that on this page:
    http://www.rayslogic.com/Propeller/Products/QMP/QMP.htm
    Only difference is that the random colors are different (because using srand) and it may be a hair slower in xmm-single/split modes.
  • dgatelydgately Posts: 1,643
    edited 2013-05-13 13:29
    Ray,
    Are you using the RamPage2 or will this run on a stock QuickStart? I'de like to check the code out once you are ready. I'm actually more interested in a C version of the Paint program as I would like to use my QMP as a touch-screen bot controller.
    dgately
    edited 2013-05-13 13:32
    dgately wrote: »
    Ray,
    dgately
    I think he's using both the QMP and the RamPage2.
    Ray: Do you have any plans to make a RamPage2 card that can be sandwiched between the QuickStart and the QMP? Or, better yet, a new QMP with at least the flash chips on it? :-)
    edited 2013-05-13 13:41
    This is with RP2+QMP on Quickstart.
    Maybe I should have put pads on the QMP for flash chips...
    I do have an RP2 sandwiched between QMP and Quickstart, but it's a very, very tight squeeze and RP2 actually has to be at an angle for it to work...
    But, there are stackable headers. Or, RP2 can mount under Quickstart.
    You don't really need XMM mode for QMP though. In cmm mode, there's plenty of space for something...
    edited 2013-05-13 13:55
    Ah, that's all I needed as I have built that in C (CMM mode version). Now just need to see if you can squeeze in the touch-screen stuff :innocent:
    dgately
    edited 2013-05-13 16:23
    I do have plans to make a GUI framework for QMP (that will also be common with VGA and DVI graphics shields and 4.3" touchscreens).
    Been waffling for a long time on whether to do it in C or Spin.
    But now, I'm leaning towards C (or C++ really)...
    edited 2013-05-13 17:47
    Rayman wrote: »
    I've been wanting to do a small, generic GUI framework for a while. I have some GUI primitives already if you want to have a look. Most of it is straight C right now, and not very generic. Would be nice to define a hardware abstraction layer. Probably some experimenting required. Want to collaborate? Maybe setup a google code project with svn?
    edited 2013-05-13 17:50
    I'm afraid I'd be a bad partner... My "plans" are usually wishful thinking at best... Maybe I'll ask for advice when and if I ever make any progress...
    edited 2013-05-13 17:56
    Decided to take the rose-colored glasses off for a second and do a real speed comparison between Spin and C++ in xmm mode...
    Here's the time to complete the demo loop:
    //50 seconds for xmm-split
    //48 seconds for xmm-single
    //42 seconds for xmmc
    //30 seconds for spin
    //45 seconds for cmm
    So, in reality xmm modes are slower in this instance, but not too bad.
    xmm-split is really the dream mode for me where I can run basically any size program I want.
    Having this at 60% of Spin speed isn't so bad...
    Tried to do this for cmm mode, but after switching from FSRW to stdio for sd card access, the program is now just a hair to big to run.
    At least, I think so. It ran fine and then froze when trying to load an image.
    HUB bytes of code is 32,700 something, so I think that's why.
    edited 2013-05-13 19:28
    Rayman wrote: »
    It's odd that xmm-single and xmm-split give you different numbers. I guess that must be because of cache collisions since data and code start at different addresses in xmm-split mode rather than being intermixed at a single address like with xmm-single. I guess we could try a separate cache for flash and SRAM to see if that improves the xmm-split performance.
    edited 2013-05-14 04:43
    Just did CMM mode on the this graphics demo and got a little puzzling results...
    The very raw output of Spin2Cpp is very, very slow because of the C replacement for "?" (random number).
    Replacing that with rand() gives:
    26 seconds for CMM
    So, that's faster than Spin.
    But, this version doesn't run in XMM mode.
    The version that I further modified to run in XMM mode gives:
    45 seconds for CMM
    Some of this difference I can tell is due to the sd driver being noticeably slower, but that's only about 2 seconds.
    I think either I did something I don't remember that slows this version down.
    Or, the HUBDATA and volatile and HUBTEXT things somehow make it slower...
    edited 2013-05-14 04:52
    Rayman wrote: »
    26 seconds for CMM
    45 seconds for CMM
    HUBTEXT will certainly not slow down the code. It should make it significantly faster. Same applies to HUBDATA. I guess volatile could slow things down because it reduces the amount of optimization that the compiler can do. However, since I think you only added volatile to mailbox variables, I wouldn't expect that the program would run at all without it.
  • ersmithersmith Posts: 6,252
    edited 2013-05-14 06:23
    What optimization options are you using for the C/C++ code? CMM mode is usually significantly faster than Spin, unless optimization is turned off. You mentioned that you've added volatile to the mailboxes, so it's probably safe to use -Os or -O2 even on spin2cpp output.
    edited 2013-05-14 08:26
    I see what was slowing the xmm version down now...
    Was copying 10 longs of parameters to the assembly driver to a local buffer before sending a command to that driver...
    I changed the code so it doesn't have to do this and now the two cmm versions are the same speed.
    edited 2013-05-14 08:59
    Ok, forget those old numbers, I've got new ones (but actually not that different except for cmm mode):
    30 seconds Spin
    27 seconds CMM mode for Spin2Cpp version (with rand() fix)
    34 seconds CMM mode for above version adapted to allow XMM mode (and using stdio for uSD instead of FSRW)
    39 seconds XMMC mode
    48 seconds XMM-Split mode
    43 seconds XMM-Single mode
