Yet another SPIN minutia question: assignment operator (and truncation)
In another thread (see here: http://forums.parallax.com/showthread.php/147876-At-wit-s-end-A-call-for-(debugging)-suggestions?p=1183045&viewfull=1#post1183045) I made an incorrect statement, claiming that the locknew example in the Propeller Manual was incorrect. Testing proved me wrong.
Distilling that down to a minimal example, why does this work when a lock is not available?:
I suppose I am assuming the value of an assignment operator is the value of the LHS symbol. It appears that the value of an assignment operator is an intermediate value, equal to the evaluated RHS. Is that close to the reason why this works?
VAR
byte lock
PUB GetLock
if (lock:=locknew) == -1
'no lock is available, take some other action here
return -1
else
return lock 'successfully reserved a lock
Before I knew enough to make incorrect statements, this looked perfectly reasonable to me. Then I learned more and became dangerous. I learned that assigning a long or word to a byte (or a long to a word) truncated the assigned value. I also learned that when a byte or word was assigned to a long (or a byte assigned to a word) there is no automatic sign extension. So clearly, assigning the value -1 to lock resulted in lock containing the value 255. 255 is never equal to -1. So just why does this work?I suppose I am assuming the value of an assignment operator is the value of the LHS symbol. It appears that the value of an assignment operator is an intermediate value, equal to the evaluated RHS. Is that close to the reason why this works?
