How to interface LISY300 Gyroscope Module with arduino — Parallax Forums
ahmedaimarahmedaimar Posts: 1
edited 2013-05-11 13:54 in General Discussion
I have LISY300 Gyroscope Module and I want to interface this module with arduino, but I cannot. Please I need help.
This is the datasheet of the module.http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/27922-LISY300GyroscopeModuleV1.0.pdf
  • ajwardajward Posts: 1,130
    edited 2013-05-11 13:46
    Hi there... this forum focuses on working with Parallax gear. Perhaps you should check the responses to your query on the Arduino forums.
    Alternatively, you might post your a picture of your wiring and your code. There are folks in these parts that are proficient with Arduino. Be aware though, posting "It doesn't work... help!" won't elicit much response.
    Good luck.
    Amanda
    Are you sure we cant change your mind and use a Propeller instead? ... here is Propeller code and a basic flow diagram intended to work with the LISY300
    http://forums.parallax.com/showthread.php/127868-Gyro-lisy300
