Rather than ask questions like "how can we have function pointers in Spin?" or "how can we do inheritance?" or "how can we do language feature X,YZ?" perhaps we should ask "What does Spin need that will make it even easier for it's intended audience of beginner programmers?"
Over the years I have noticed that a recurring question from newbies to Spin (and programming at all) goes something like this:
"How do I send messages to FullDuplexSerial from a piece of code in an object that is not the one that included FDS?"
Think about it from a newbie perspective. He can write seral.tx("Hello world") in one place and that's OK but he cannot write the same thing somewhere else. Makes no sense whatsoever does it.
Said newbie does not want to know about function pointers, or passing objects or inhertance or any other such complication. He just wants to write what he knows works in a place where it does not.
I hate to say this but it seems to me the easist way to fix our newbies problem is to have the possibility of globaly scoped objects!
Job done. His serial.tx("hello world") now works everywhere as he rightly expects it to.
I guess what I'd really like to see is support for inheritance and passing object references as parameters to functions. This would make objects first-class data types. I guess that's not likely to happen though because it would pretty much require a type system.
The compiler can keep track of objects and their references, I'm sure the compiler has a symbol table to keep track of variable reference already, this would be an extension.
It's not far fetched to implement inheritance (single or multiple? definitely only one level of derived class though) and object passing.
'Seems like you ought to be able to pack "object/instance #17:pub #2" in 32 bits or less. It's just a table lookup from there.
I think function references would be easier to implement than object references. The reason is that, in the latter, the object code would have to include a dictionary (i.e. public method symbol table) for each object, unless you also enforced a rule that object methods (e.g. tx and rx would not only have to be named the same but occur in the same order across all such objects.
lets just summarize what SPIN currently does and where the problems are why we need something like function or object pointer.
As long as your object does not have VAR sections you can include it into all objects needed and it will be pruned down by the compiler to just one instance.
That can take care of some formatter-object like Phil is talking about, but you have to include it into every object. (and adapt for things like out vs tx etc). uncool.
You CAN call a spin-function via cognew - alas it is a own instance with a own stack running on another cog/spin-interpreter. also uncool.
Throwing the whole OO Paradigma with inheritance, overloading, casing and a type-system onto SPIN would be nice, but IMHO not feasible. Keep it simple.
Since I am german I might be a little blue-eyed here but is it not possible to get a pointer to an existing instance of a object and pass that thru to another sub-object?
As far as I understand this, the dynamic object loader DOL is doing this the hard way, iterating thru SPINs HUB memory to pick those values out of it and simulating a call?
So can not the compiler do the same?
As Phil said, sio.tx refers to a instance and not a class. Even if we would need a 64bit pointer couldn't take the compiler take care of this?
we do not need a fullblown type system for this, just one more type: 64bit function/object-pointer.
I would be fine with just being able to use a function-pointer like sio.rx inside a call to another sub-object, but having a reference to the whole object sio would be better.
Could someone explain to me in what possible way function references would be useful?
This would make Spin a bit of an odd ball language. Spin only has objects and methods, there are no free standing functions. So a pointer to a method without any knowledge of it's instance is, well, odd ball. You cannot do that in C++ or Java for example.
That method that you are about to call through a pointer had better not be using any non-local variables or something is going to explode.
Exactly. That's why object pointers would be difficult. Method pointers, though, which support proper state context would be doable.
Here's how it could work:
***** top-level object
VAR
long mptr[3] 'method pointer, holds VBASE, PBASE, and PUB/PRI index number
OBJ
serial : "serialport"
print : "printvalue"
PUB Start
serial.start(31, 30, 19200)
mptr := @out 'set mptr to current VBASE/PBASE and index of 'out' method (3 longs)
print.setptr(@mptr) 'pass mptr address to 'print' object's 'setptr' method
'at this point, 'print' object has full pointer to 'out' method, so
'it can pass data back to this object
print.binary($FFFF) 'print binary value to 'out' method
PRI out(chr)
serial.tx(chr)
***** "printvalue" object
VAR
long outptr
PUB setptr(p)
outptr := p
PUB binary(value)
repeat 32
value <-= 1
@outptr("0" + (value & 1))
Will this not deliver the desired goods?
When the compiler sees @variable at the start of a line, it knows this is an indirect 'object.method' call.
When the compiler sees @method on the right hand of an assignment, it knows this must be a 3-long write into a long array to establish an 'object.method' pointer.
There are no caveats with VAR/DAT sections on either side of the usage.
Yes, that would work. But would there be any way for behind-the-scenes magic to make print.binary(@out, $ffff) work? ("Behind-the-scenes magic" is what I meant by complicating the backend to make the frontend simple.)
Would this suffice?
VAR
OBJ
PUB Start
outptr := @out 'set outptr to current VBASE/PBASE and index of 'out' method (3 longs)
print.binary(@outptr, $FFFF) 'print binary value to 'out' method
PRI out(chr)
serial.tx(chr)
PUB binary(outptr, value)
repeat 32
value <-= 1
The thing is, there are three longs that must be conveyed to form a complete 'object.method' pointer. To fake it in a parameter list would be a little misleading, not to mention much less efficient than just passing the address of the method pointer, itself.
Yes, "function" and "method" get used interchangeably a lot. Makes no difference to my arguments.
By taking a pointer to a method (only) one has effectively made it a function as it has no object context anymore.
However I see from Chip's example he has in mind a "mega-pointer" that gets you to the object context as well. So it is more than a function pointer.
What I don't like about Chip's example is the extra layer of indirection with mptr and having to bounce through the current objects out method when making the call from inside print to serial.out. All seems rather messy.
VAR
OBJ
PUB Start
PRI out(chr)
serial.tx(chr)
VAR
long outptr
PUB setptr(p)
outptr := p
PUB binary(value)
repeat 32
value <-= 1
Yes. This is precisely what we need. And this is quite simple and easy to understand.
If spin gets too complex, then we may as well abandon it, and push into C.
I don't see function references being anything more than a hack, object references, while more difficult, are significantly more useful.
The syntax Chip posted was not simple and straightforward, it relied on ~magic~, which is the worst possible thing you can do.
The only reason to continue down the function pointer road is if SPIN isn't getting inheritance and object passing, but then I'd rather just hack something more intuitive in PASM or write good looking code.
Chip, I guess I'm confused as to why the double indirection is necessary. Couldn't @out simply be made to point to the three-long table?
Why do we have to point to anything? Make the language abstract this completely from the programmer, then the backend can do 3 longs if it needs to. By that time you are better off just pointing to an object.
I guess we can disagree on that. Method references are easy to grasp without invoking a bunch of OOP stuff that Spin has (mercifully) left out. At least that's my take.
Your first example was better, in the last I have to include the @mptr parameter everytime I print something which might be often.
I didn't like the first example at all, because the call to setptr hides the referrent from subsequent method calls. Hidden variables can cause debugging headaches. Moreover, with multiple output streams, you'd have to change gears every time you print to a different output. It's a difference between "aim at A; shoot; aim at B; shoot" and "shoot at A; shoot at B." The latter seems simpler to me.
You could have 'serial' make the "mega-pointer" and pass you its address, which you hand off to 'print', instead of the pointer to your 'out'.
If 'serial' had a method to make and give you the address of the "mega-pointer", then it could look like this:
OBJ
PUB Start
print.binary(serial.outptr, $FFFF) 'print binary value to 'out' method
repeat 32
value <-= 1
Of course, it would be faster to not do 'serial.outptr' every time you printed something, but rather do that once and save that pointer address in a VAR long.
The '@methodptr' on the start of a line could be overloaded to accept '@methodptr[index]' which would add to the PUB/PRI index, so that you could call a range of methods, starting at the original pointer's index.
That's getting better, IMO. Is the "@" in @outptr("0" + (value & 1)) really necessary? It kind of carries the reverse semantics of other @'s. The parens should be enough context to denote a method call, with method_name() being okay for parameterless calls.
That could be used to make a pointer to a child object's method! Or, used to get the address of some VAR or DAT resource. Wait... it could do ALL the above, as the compiler would know the context.
Now what happens when I want to use serial from something a bit more challenging that print?
I might have some complex protocol driver that can be used with any serial device. Now I need a mega_pointer for "in" as well and perhaps other methods on the serial device. This could get out of hand.
Enjoy
***** top-level object VAR long mptr[3] 'method pointer, holds VBASE, PBASE, and PUB/PRI index number OBJ serial : "serialport" print : "printvalue" PUB Start serial.start(31, 30, 19200) mptr := @out 'set mptr to current VBASE/PBASE and index of 'out' method (3 longs) print.setptr(@mptr) 'pass mptr address to 'print' object's 'setptr' method 'at this point, 'print' object has full pointer to 'out' method, so 'it can pass data back to this object print.binary($FFFF) 'print binary value to 'out' method PRI out(chr) serial.tx(chr) ***** "printvalue" object VAR long outptr PUB setptr(p) outptr := p PUB binary(value) repeat 32 value <-= 1 @outptr("0" + (value & 1))Will this not deliver the desired goods?
I think "function" and "method" are being used interchangeably here. At least that's been the case in my posts.
Would this suffice?
***** top-level object VAR long mptr[3] 'method pointer, holds VBASE, PBASE, and PUB/PRI index number OBJ serial : "serialport" print : "printvalue" PUB Start serial.start(31, 30, 19200) outptr := @out 'set outptr to current VBASE/PBASE and index of 'out' method (3 longs) print.binary(@outptr, $FFFF) 'print binary value to 'out' method PRI out(chr) serial.tx(chr) ***** "printvalue" object PUB binary(outptr, value) repeat 32 value <-= 1 @outptr("0" + (value & 1))The thing is, there are three longs that must be conveyed to form a complete 'object.method' pointer. To fake it in a parameter list would be a little misleading, not to mention much less efficient than just passing the address of the method pointer, itself.
That would do very nicely for most of my needs...
another thing I am missing is
Enjoy!
The 3-long pointer is unique to the instance of the object establishing it, so it must live in VAR space and be resolved at run-time.
I know. The second example was superfluous and meant to show more compact (but less efficient) code to somewhat satisfy Phil's desire.
***** top-level object OBJ serial : "serialport" print : "printvalue" PUB Start serial.start(31, 30, 19200) print.binary(serial.outptr, $FFFF) 'print binary value to 'out' method ***** "printvalue" object PUB binary(outptr, value) repeat 32 value <-= 1 @outptr("0" + (value & 1))Of course, it would be faster to not do 'serial.outptr' every time you printed something, but rather do that once and save that pointer address in a VAR long.
Mike,
I'm still thinking.
As I never analysed SPIN interpreter so much --- Need much thinking before I can say anything.
My concerns now are Good Assembler -- Spin are second part for me.
And as P2 give me possibility to program in RAW assembly -- That is my first choice
You're right, Phil! That's a lot better.
